Aftermarket Water Temp Gauge Suggestions - Page 2 - JeepForum.com
post #16 of 25 Old 06-18-2013, 07:11 PM Thread Starter
rickscj7boom
Thanks turbogus, this is the update on my mech water temp mission... I have moved from therm housing area and decide to try elsewhere , picked up a sun pro gauge and going to the next step .. Here are some pics of driver side motor area, might one of you guys be so kind in pointing out which one of them outlets I can plug the therm probe into? Here are some pics I took of the engine .. I don't know how to label pics but lets just number them for top to bottom 1-7.... My guess is 7 by looking at some other threads on here.. Thank you for caring and showing jeep love to a total strange with the same illness the JEEP'N Curse.. Pic 1 is my failed attempt in the housing, the probe hits the inside of housing, it too long... Still leaked
image-2015090833.jpg   image-527521527.jpg   image-98142562.jpg   image-793156862.jpg   image-2698418748.jpg
rickscj7boom is offline
post #17 of 25 Old 06-18-2013, 07:26 PM
rplivin
Mine is in number 4 but I have 0 emission equipment
rplivin is offline
post #18 of 25 Old 06-18-2013, 07:30 PM
rplivin
Pic 6 one on top has solid bottom one one bottom left is a large hole to water port as is the vacuum switch to the right of it.
rplivin is offline
post #19 of 25 Old 06-18-2013, 07:34 PM
Bubba Ray
You could make a small ext. for the sensor and still use the stat housing.
Bubba Ray is offline
post #20 of 25 Old 06-19-2013, 02:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Depending were you lie I would not do #4. IF it gets cold, you would need this switch to heat the manifold up to keep from stumbling.
I like #1 of course. I can't believe with such a short sweep it has such a long bulb.
I would probably go with #6 if it fits. That switch is probably not doing anything anymore.
I would do this if #1 is not an option
John Strenk is online now
post #21 of 25 Old 06-19-2013, 06:16 AM
wvrefugee
1979 CJ7
I installed Auto Meter Phantom white faced gauges in the CJ and have been pleased thus far.........it's all about the sending units!!!
http://i90.photobucket.com/albums/k251/wvrefugee_2006/chimneytops.jpg
wvrefugee is offline
post #22 of 25 Old 06-19-2013, 09:52 AM
Balvar24
1979 CJ7
I think that I had to use the red arrow in Strenk's post above with the Sun Pro. IIRC, the yellow arrow is too near a cylinder wall. I used the cheapy SunPro gauge as well.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #23 of 25 Old 06-19-2013, 10:55 AM
ChaseKanter
Just bought a sunpro too! I was planning on using the port with the red arrow in the pic above.
ChaseKanter is offline
post #24 of 25 Old 06-22-2013, 02:34 PM Thread Starter
rickscj7boom
I removed that (pic1), installed the temp gauge and ran with it.. After 5 mile test drive gauge went up to about 190 , what do you guys think? Did I put the sensor in an "ok" place?
image-3188337144.jpg   image-3526894368.jpg   image-2609893680.jpg   image-2711070535.jpg
post #25 of 25 Old 06-22-2013, 02:37 PM
davbytrace
1979 CJ7
VDO Classic Series matches the Jeep. Be sure to get the matching sender.
davbytrace is offline
