Aftermarket Water Temp Gauge Suggestions - JeepForum.com
post #1 of 25 Old 06-10-2013, 01:01 PM Thread Starter
rickscj7boom
ok guys, I don't trust my original temp gauge, i'm thinking of buying an aftermarket gauge... I have a 84 CJ7 i6... what have you guys bought and trust that it worked for you... pics or some info would be kind... thanks
rickscj7boom is offline
post #2 of 25 Old 06-11-2013, 06:45 PM
drerict
1983 CJ7
I would like to know also . . . someone please respond
Firefighters Jeep Club
drerict is offline
post #3 of 25 Old 06-11-2013, 07:28 PM
SCSEAJAYSEVEN
1978 CJ7
All of my gauges in my '78 CJ-7 are SunPro,a division of Snapon Tools. I have the 2-1/8" gauges mounted in the dash. I have the mechanical water temp, mechanical oil pressure, vacuum gauge, electrical volt meter and a mechanical econo performance gauge and an electric tachometer mounted at the top of the steering column. I bought every one of them at Autozone or Advance Auto Parts.
I trust all of them, as they work well.
SCSEAJAYSEVEN is offline
post #4 of 25 Old 06-11-2013, 07:37 PM
robs7
1983 CJ7
I have the Sunpro gauges as well. Very economical, look good, and I trust them. Rob
robs7 is offline
post #5 of 25 Old 06-12-2013, 01:27 PM Thread Starter
rickscj7boom
these mechanical gauges you guys speak of, did the sensor part of it fit into the block perfectly or did you guys use a thermostat housing type that a sensor can be put into it... the gauges I've seen so far looks like the sensor part wont fit the existing hole in the engine block.. please correct me if i'm wrong, i'm a rookie at all this..
post #6 of 25 Old 06-12-2013, 01:30 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Mechanical Temp sensor wont fit original hole.
Some use a hole in the block but I think the Thermostat housing is the best.
John Strenk is offline
post #7 of 25 Old 06-12-2013, 01:34 PM
Balvar24
1979 CJ7
This.
I had to use a CTO hole in the block.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #8 of 25 Old 06-12-2013, 01:40 PM Thread Starter
rickscj7boom
thank you sir.. finding a thermostat housing with that option, I will research it but if you have a link or part number would be awesome.. how close of years in jeeps is the housing the same ... I found these links, is this what I need?
http://www.newegg.com/Product/Produc...9SIA1G20GD3248
post #9 of 25 Old 06-12-2013, 01:49 PM
John Strenk
1976 CJ5
That seems to be for a V8.
Usually the 4.0 thermostat housing will be just what you need for a 258 i6.
http://www.quadratec.com/products/51209_08.htm
post #10 of 25 Old 06-12-2013, 02:04 PM Thread Starter
rickscj7boom
perfect sir... thanks.. .. you guys rule!!
post #11 of 25 Old 06-18-2013, 12:52 AM Thread Starter
rickscj7boom
Ok guys, so I got the housing suggested above . My new problem is that the temp gauge probe is to long and hits the inside of the housing .. Did I get the wrong temp gauge, do they sell one with a shorter temp gauge probe..
post #12 of 25 Old 06-18-2013, 09:46 AM Thread Starter
rickscj7boom
Even with the brass fitting it came with it still hits..
post #13 of 25 Old 06-18-2013, 10:02 AM
John Strenk
1976 CJ5
Who's gauge did you buy?
post #14 of 25 Old 06-18-2013, 10:20 AM Thread Starter
rickscj7boom
This is what autozone and orileys have down here
http://www.oreillyauto.com/site/c/de...0527&ppt=C0134
post #15 of 25 Old 06-18-2013, 02:41 PM
turbogus
1978 CJ5
They may not be the best (or brightest) gauges but I've always used Auto Meter gauges and whatever gauge you go with I reccomend a wide sweep 270* gauge.
As I wanted to keep that factory electrical gauge in the speedometer hub I had only one spot for the sender on this gauge, in a water jacket on the intake manifold;
Edit. There was a steel pipe plug in this port when I got 'BB' had to use PB and my little butane torch to get the little facker out. Then it was just a matter of getting a common adapter from NAPA in their brass and copper fittings area.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
