-   -   Aftermarket Water Temp Gauge Suggestions (http://www.jeepforum.com/forum/f8/aftermarket-water-temp-gauge-suggestions-1534704/)
rickscj7boom 06-10-2013 01:01 PM
ok guys, I don't trust my original temp gauge, i'm thinking of buying an aftermarket gauge... I have a 84 CJ7 i6... what have you guys bought and trust that it worked for you... pics or some info would be kind... thanks
drerict 06-11-2013 06:45 PM
I would like to know also . . . someone please respond
SCSEAJAYSEVEN 06-11-2013 07:28 PM
All of my gauges in my '78 CJ-7 are SunPro,a division of Snapon Tools. I have the 2-1/8" gauges mounted in the dash. I have the mechanical water temp, mechanical oil pressure, vacuum gauge, electrical volt meter and a mechanical econo performance gauge and an electric tachometer mounted at the top of the steering column. I bought every one of them at Autozone or Advance Auto Parts.
I trust all of them, as they work well.
robs7 06-11-2013 07:37 PM
I have the Sunpro gauges as well. Very economical, look good, and I trust them. Rob
rickscj7boom 06-12-2013 01:27 PM
these mechanical gauges you guys speak of, did the sensor part of it fit into the block perfectly or did you guys use a thermostat housing type that a sensor can be put into it... the gauges I've seen so far looks like the sensor part wont fit the existing hole in the engine block.. please correct me if i'm wrong, i'm a rookie at all this..
John Strenk 06-12-2013 01:30 PM
603 Attachment(s)
Mechanical Temp sensor wont fit original hole.
Some use a hole in the block but I think the Thermostat housing is the best.
Balvar24 06-12-2013 01:34 PM
This.
I had to use a CTO hole in the block.
rickscj7boom 06-12-2013 01:40 PM
thank you sir.. finding a thermostat housing with that option, I will research it but if you have a link or part number would be awesome.. how close of years in jeeps is the housing the same ... I found these links, is this what I need?
http://www.newegg.com/Product/Produc...9SIA1G20GD3248
John Strenk 06-12-2013 01:49 PM
603 Attachment(s)
That seems to be for a V8.
Usually the 4.0 thermostat housing will be just what you need for a 258 i6.
http://www.quadratec.com/products/51209_08.htm
http://www.quadratec.com/Assets/Imag...9/33709-lg.jpg
rickscj7boom 06-12-2013 02:04 PM
perfect sir... thanks.. .. you guys rule!!
rickscj7boom 06-18-2013 12:52 AM
1 Attachment(s)
Ok guys, so I got the housing suggested above . My new problem is that the temp gauge probe is to long and hits the inside of the housing .. Did I get the wrong temp gauge, do they sell one with a shorter temp gauge probe..
rickscj7boom 06-18-2013 09:46 AM
Even with the brass fitting it came with it still hits..
John Strenk 06-18-2013 10:02 AM
603 Attachment(s)
Who's gauge did you buy?
rickscj7boom 06-18-2013 10:20 AM
This is what autozone and orileys have down here
http://www.oreillyauto.com/site/c/de...0527&ppt=C0134
turbogus 06-18-2013 02:41 PM
They may not be the best (or brightest) gauges but I've always used Auto Meter gauges and whatever gauge you go with I reccomend a wide sweep 270* gauge.
http://farm6.staticflickr.com/5249/5...176ebfb6_z.jpg
As I wanted to keep that factory electrical gauge in the speedometer hub I had only one spot for the sender on this gauge, in a water jacket on the intake manifold;
http://farm2.staticflickr.com/1302/4...28901c35_z.jpg
Edit. There was a steel pipe plug in this port when I got 'BB' had to use PB and my little butane torch to get the little facker out. Then it was just a matter of getting a common adapter from NAPA in their brass and copper fittings area.
The time now is 09:22 AM.
