aftermarket tach installation- where does the green wire go? - JeepForum.com
post #1 of 8 Old 08-30-2013, 05:58 PM Thread Starter
jennkent5454
1979 CJ5
I have an aftermarket tach I am wanting to use under the hood for setting the timing. since my coil doesnt have a negative terminal post to hook the green wire of the tach to which wire should I connect it to? I assume to the green wire coming from the coil but want to be 100% sure first.
jennkent5454 is offline
post #2 of 8 Old 08-30-2013, 06:00 PM
CJ7ROB
Use one of those wire tap connectors that taps into a wire. You use a pliers to push the metal tab down into the wires. They aren't the best though..
http://tech.bareasschoppers.com/reso...ap-connectors/
CJ7ROB is offline
post #3 of 8 Old 08-30-2013, 06:02 PM Thread Starter
jennkent5454
1979 CJ5
exactly what I was going to do but really need to know if I use the green wire from the coil?
post #4 of 8 Old 08-30-2013, 06:11 PM
CJ7ROB
If that green wire on the coil is the negative one, then yes tap into that one.
CJ7ROB is offline
post #5 of 8 Old 08-30-2013, 06:19 PM
shadoow
the terminal on the coil with the green wire is the negative terminal. Also called the tach/test terminal. If you remove the plastic top cover on the coil where the wires attach and look at the coil terminals the one for the green wire should have a "-" next to it.
shadoow is online now
post #6 of 8 Old 08-30-2013, 06:27 PM
WindKnot
1977 CJ7
You're asking for trouble with those. They leave you wide open to corrosion. the BEST way is to cut it, twist the wires together and solder it with a weatherproof shrink wrap sleeve to go over it. Yes, it is worth the trouble.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 8 Old 08-31-2013, 07:37 AM
CSP
Take that plastic cover off and there's a terminal there you can use to attach the wire to.
CSP is offline
post #8 of 8 Old 09-01-2013, 10:17 PM
BigJack1976
1976 CJ5
Don't know if you have figured it out yet ,but yes the green wire is the negative coil wire.
BigJack1976 is offline
