Aftermarket tach install with Team Rush TFI/HEI upgrade
#1 | |
I have a tach laying in the CJ I want to install before I set the timing and tweak my 2100.
I was just reading the Teamrush sticky and didn't see it. Did a couple searchs, but maybe my terminology is off? I'm seeing lots of discussion on the TFI/HEI stuff, but no tach info. I'm looking for something butt simple to follow, green wire goes here...... red wire goes here........ Anything to help make the trailride Saturday. Thanks a million. ![]() EDIT: Changed the search terms again, got some basic tach instructions. On it.
79' CJ7 - D30/D44, T150/D20, 3.73's, 4" with 33" KM1, winch, skids, homemade bumpers, spray paint and a cool shift knob. 98' TJ D30/D35, 2.5" lift, 31's on Rubi rims, winch, skids, she wheels it. 06' COMMANDER, 2" lift. |
#2 |
OIIIIO
Don't know if this will help you, but I had it marked for a future mod. Not sure if you have a factory tach. or as you said aftermarket, so I am assuming it's not a factory style tach. which is in series I believe.
http://www.jeepforum.com/forum/f8/cj7-factory-tachometer-installation-write-up-502113/
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20. 1986 CJ10-A SD-33 Diesel/727/np208 1971 800B with 345/T-19 88' Comanche, 4.0L F.I., 5 spd. |
#3 |
Running On Empty...
The usual AFTERMARKET tach is an 'Add On'...
Will usually have RED & BLACK wires, those are power. Negative is 'Ground', and usually 'Black'... Power to the tach is usually 'Red' and should be 'Switched' from the ignition or accessory power. There is usually a 'Green' wire, and that will connect to your coil Negative connection. There will be a 'Odd Color' wire, blue, yellow, white, something like that... That will be the Gauge Light... ---------------------------------------------- You didn't say anything about FACTORY tach, so if it's a factory tach, the wire colors will change by year and number of cylinders it's supporting. Coming out of the Ignition switch, you will find a 10 Gauge RED wire, and a few inches from the ignition switch, you will find an electrical connector. That electrical connector is where you pull apart, and install the two heavy wires from the factory tach. The two smaller wires to the factory tach will be 'Ground' and 'Dash Light'. This V-8 tach is wired like mine, Black is ground, Orange is Dash Light, The two reds wires are Ignition Power Into the tach, And ignition power out of the tach to the ignition.
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, Last edited by JeepHammer; 02-19-2009 at 10:13 PM.. |
#4 |
You guys are huge. I'm trying like hell to make this inaugoral trailride, and without the help here, it couldn't have been done.
That siad, tach is a aftermarket sunpro unit. Got green, red, black, white wires. I have to factory tach in my rig. Thanks a bunch!!
#5 |
green goes to neg on coil, red is power, white is for the light, black is ground. i just put one of the sunpro tachs on my jeep a couple months ago.
79 cj5/258ci/2.5" pro comp lift/31" tires/team rush/msd box/motorcraft carb |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
