Aftermarket or homemade dome light ideas. - Page 2 - JeepForum.com
post #16 of 23 Old 02-08-2013, 06:43 PM
bear991
1978 CJ7
I use a maglite.....lol works everytime
bear991 is offline
post #17 of 23 Old 02-08-2013, 07:02 PM
adams1985cj
Originally Posted by ElbeHills View Post
This one is pretty cool. All machined and anodized aluminum with a contour to fit the bar. We chased the wires through the cage and ran a switch in the dash. It's super bright too. $40 on eBay.
Attachment 559475
Built not Bought!
What did you search for when you found this. I have tried several different searches and have not come across it. Thanks
You donít buy it you build it!!
adams1985cj is offline
post #18 of 23 Old 02-09-2013, 09:24 AM
WSS
WSS's Avatar
1972 CJ5
"billet led dome" works on ebay, look for the radius mount type. I used this for the front:
http://www.ebay.com/itm/221158168294...84.m1497.l2649
and two of these for the rear:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=221178464703
The back is controlled by the rear passengers via a switch on the back of a tuffy console and the front is controlled by a dash mounted switch. Or I should say will be LOL still getting it all together. The leds mount in some brackets welded to the cage, kind of dual purpose gussets and led holders.
The leds are fairly bright compared to a regular dome light and vibration a water proof.
WSS
WSS is offline
post #19 of 23 Old 02-09-2013, 05:36 PM
WSS
WSS's Avatar
1972 CJ5
Put them in today but did not get them wired. The larger light has three leds inside and the smaller two are single leds.
WSS
WSS is offline
post #20 of 23 Old 02-23-2013, 11:28 PM
WSS
WSS's Avatar
1972 CJ5
Wired the back two to one switch. The main "hot spot" is right on the fender well, were you would put a map or directions. The rest of the rear has a nice led glow. Perfect.
WSS
WSS is offline
post #21 of 23 Old 02-24-2013, 07:40 AM
hasselback
For mine, I got a rear view mirror from the junkyard with maplights built in. not sure what it came out of, but its pretty bright, and lights up the whole front cab area.
hasselback is offline
post #22 of 23 Old 02-24-2013, 02:31 PM
wingedmare
1981 CJ5
I opted for a book lamp with a clip and attached it to my visor.....
http://jeepin29.blogspot.com/ ~ My blog about how my Jeep has affected my life and how I use it to refresh myself. Have a look if you're intereseted.
wingedmare is offline
post #23 of 23 Old 02-24-2013, 03:59 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I used one the GM retractable lights (thanks for the idea Keith) connected to 12v power at my amp. It has a 25' reach with a magnetic end, so I can use anywhere inside or out of the Jeep.
Matt
Matt1981CJ7 is online now
