After a winter in storage, CJ7s brakes weak - JeepForum.com
post #1 of 5 Old 05-14-2013, 10:11 AM Thread Starter
TitanJeff
I have an '84 CJ7 which sits in a garage all winter. I charged up the battery and got it running today to find the dashboard brake light staying on and the brakes generally very weak.
I did search for the issue here but I didn't find anything that seemed to fit my issue. I don't see anything that appears to be leaking brake fluid. I don't have much resistance when pushing the brake pad until it's close to the floor. Pumping the brake seems to make the situation a little better.
Any thoughts? Thanks.
TitanJeff is offline
post #2 of 5 Old 05-14-2013, 10:32 AM
GuacaTex
1981 CJ7
If no leaks, you probably have bad seals in your master cylinder. Time to replace/ rebuild it.
GuacaTex is offline
post #3 of 5 Old 05-14-2013, 10:37 AM Thread Starter
TitanJeff
Thanks for the reply.
I'm not a mechanic so will need to find someone. Any idea of a range this repair might cost?
post #4 of 5 Old 05-14-2013, 11:57 AM
GuacaTex
1981 CJ7
No clue what a shop would charge. Master cylinders can be had for < 80$. Less if you go with remanufactured. Rebuild kits look to be about 35$. I think you can get a remanufactured one from your local parts house for less than the cost of the rebuild kit.
GuacaTex is offline
post #5 of 5 Old 05-14-2013, 01:05 PM
caseypotts
1980 CJ7
Think I paid 60 a couple weeks ago with a $15 core charge.
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
