after tub lined where to start using caulk to seal from rain water? - JeepForum.com
post #1 of 3 Old 10-21-2013, 09:22 PM Thread Starter
seabass1858
1983 CJ7
After i change the cowl seal and coat my floor with bed armor, where all should i be looking at using automotive caulk to eliminate rain water from leaking in that area?
seabass1858 is offline
post #2 of 3 Old 10-21-2013, 11:30 PM
tombstne
1982 CJ7
I had a leaking cowl seal also, I used 2 sided tape and put it between windshield frame and seal. I used HD tape which is a bit thick but it has sealed it for 2 rain seasons with no leaks there.
tombstne is offline
post #3 of 3 Old 10-22-2013, 07:28 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Seabass,
Similar to Tombstone, I ran a bead of black silicone between the upper flap of the cowl seal and the frame. If you don't glue that flap down, it will eventually curl away from the frame causing leaks. Pay special attention to the areas around the hood hinges, and at the ends of the cowl seal on the sides of the frame.
Good luck,
Matt
Matt1981CJ7 is offline
