Advise on putting the jeep body together - JeepForum.com
post #1 of 7 Old 11-12-2008, 08:00 PM Thread Starter
stephens_cj5
1981 CJ5
Need some advise on putting the jeep back together. I attached some pictures so you can see where I was and what I have now.
- Should I use seam sealer under the hinges or some sort of gasket?
- Should I attach the hinges prior to painting?
- Has anyone used Quietcar (http://quietcoat.stores.yahoo.net/) instead of Dynamat?
- I plan to use Raptor in the tub and need to know if there is a risk of applying it to the top edges of the tub. The idea is to help prevent scratches.
- What do I use between the fenders and tub? Again I was thinking about some gasket material.
Keep in mind this is my first attempt at this but its damn near impossible to get the waves out of these tubs.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline
post #2 of 7 Old 11-12-2008, 09:28 PM
Slawth
Master Rebater
Slawth's Avatar
1978 CJ5
- Should I use seam sealer under the hinges or some sort of gasket?NO
- Should I attach the hinges prior to painting?I would paint them separately since you have gone this far.
- What do I use between the fenders and tub?NothingAgain I was thinking about some gasket material.I would not. You are only going to trap water causing premature rust out in the future.
Keep in mind this is my first attempt at this but its damn near impossible to get the waves out of these tubs. They didn't bother to do so from the factory. You'll about kill yourself trying to get them perfect in your garage,lol.
Nice work. What color are you painting it?
Slawth is offline
post #3 of 7 Old 11-12-2008, 09:41 PM
Floridazed
Floridazed's Avatar
1980 CJ7
No gaskets between fenders. Just paint.
Speaking of, just make sure you have paint under the hinges, Either paint under-install-paint all. or paint entire hinge-install after paint of bdy. Either works.
Dont use any silicon gasket or sealers.
As for waves... they can be done. bondo...sand...repeat. easier said than done, eh?
Also... Fit all first if you bought new fenders or hood. Aftermarket sucks, they are always off a tad.
Andy
_______________
1980 CJ-7 : 151GM : Stock : In process of restoration (always constant, and something to do.)
Floridazed is offline
post #4 of 7 Old 11-13-2008, 06:59 AM
neals80
1980 CJ7
use a best type bondo from bondo now owned by 3M...like a marson premium filler...it is about $30 a gallon but will
sand better and last forever....
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline
post #5 of 7 Old 11-13-2008, 07:09 AM
rixcj
rixcj's Avatar
1979 CJ5
When doing a restoration, the bodywork is usually the most time consuming.
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #6 of 7 Old 11-13-2008, 08:27 AM Thread Starter
stephens_cj5
1981 CJ5
I used Rage bondo and it seemed to have worked well. It was easy enough to sand and work with. And yes the body work is and was the most time consuming. Thats where I hope to make my money.
post #7 of 7 Old 11-13-2008, 02:27 PM
my84cj7
Rage is the best bondo to use, and trust me I have tried them all. Get rage extreme because it sands a little better, but if you can't get that get rage gold it works well too. You can also get some glaze putty for when you get closer to being finished, and when you are ready to put some skim coats on. This mixes the same as bondo but you need to let it dry until it gets pretty hard but with some 80grit it sands pretty smooth and will help you get it fairly straight before you apply your primer. I can go into where to get this stuff and what is the best primer also if you need me too, just let me know.
my84cj7 is offline
jeep floor rebuild+body support rail+ 1" hockey puck body lift canadianwinter Jeep CJ Forum 46 03-12-2010 12:26 AM
First time Jeep owner need tech advise luca_marine Jeep CJ Forum 13 12-03-2009 01:00 PM
Advise on used Jeep SHAFT Jeep CJ Forum 4 07-20-2006 12:25 AM
New Jeep Owner (84 CJ7) -Please Advise jcrews34 Jeep CJ Forum 9 06-25-2006 11:47 PM
Problems when putting on a Body Lift??? Marion Jeep CJ Forum 1 06-07-2006 05:57 PM
