advice on rebuilding stock rear in a '79 cj - JeepForum.com
post #1 of 2 Old 06-26-2002, 02:30 PM Thread Starter
navycj7
Post advice on rebuilding stock rear in a '79 cj
I have a damaged rear in my 79CJ and want to upgrade. Currently has 33x12.5 tires, very little off road use. I have mechanical ability but uncertain if this job too big. Advice or links to advice welcomed.
navycj7 is offline
post #2 of 2 Old 06-26-2002, 07:33 PM
cjdriver
cjdriver's Avatar
Post
What do you want to switch to? You need to give a little more info than that. Depending on what you are looking to do you very well might be able to do it. Certain things are not too hard. If you want to put a Lock Right and some one peice axles in your current one you should be fine with relatively decent mechanical knowlege. If you want to swap a whole new unit in there you should be able to do that as well relatively easily. If you want to change gears, well that requires quite a bit more knowlege and skill. Let us know what you want to do and we'll see what we can do.
Jim Sykes
motorsports photography
cjdriver is offline
304 v8 stock carburetor question/advice houstonmat Jeep CJ Forum 14 02-02-2012 12:43 PM
Rebuilding a 258 advice... Raccroc Jeep CJ Forum 1 08-26-2009 04:25 PM
stock rear bumper? Tow points in the rear... jlr69s Jeep CJ Forum 17 05-15-2008 07:23 AM
Radiator advice... stock or aluminum? SuB8HaVeN Jeep CJ Forum 9 02-26-2008 12:42 PM
Rebuilding 258 - headers or stay stock? heath84CJ7 Jeep CJ Forum 1 03-14-2007 12:33 PM
