Advice on paint - JeepForum.com
post #1 of 7 Old 01-30-2014, 11:27 AM Thread Starter
00rooster
1977 CJ5
Advice on paint
I'm doing a full body off restoration job on a '77 CJ. The tub was pretty well shot, and debated about just buying a new one, but didn't want to part with the bones to get one. And since I'm handy with a welder I am tackling the job myself. Its been an interesting process, but I'm getting closer to the painting part of it.
This isn't going to be a showroom jeep, its will be a trail-runner so I don't care about glossing or flawless finishes. Practicality trumps appearance.
Does rhino lining under the tub work good? This jeep will be almost exclusively driven on dirt and gravel roads. I want to paint it to look like a Humvee, with the flat sand/tan color. I've done some reading on the CARC that they paint Humvees with and it looks like something that I wouldn't want to do in my shop. Can you paint over rhino lining? because I'd like to rhino line my floor too, but don't want my floors black.
I have an air compressor and simple paint gun, so I could just buy a couple of gallons of flat tan Rust-o-leum, any other options?
If I took it to a paint shop how much does that CARC cost? will it break the bank, or is it reasonable.
00rooster is offline
post #2 of 7 Old 01-30-2014, 01:42 PM
dg6772
I used Valspar dark green metallic on my CJ 7. I wanted it to look ok but I drive it all over the place. DD,trail rider,mud pits,etc. Paint was 35.00/gal plus the reducer and hardener. I actually spent more money on my urethane primer than my paint. Was easy to do in my home garage. Its not perfect,but it looks ok and I'M happy with it.
Dave in Muskegon using JeepForum
dg6772 is offline
post #3 of 7 Old 01-30-2014, 01:47 PM
dg6772
Btw prep is probably more important that anything else. The better the prep the better the outcome.
I also used a spray-on undercoating on the bottom of my cj,from advanced auto.
dg6772 is offline
post #4 of 7 Old 01-30-2014, 04:42 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Personally, I wouldn't want to paint it with any color or any product that I couldn't readily find touch up paint for at the local auto parts store. If you like the desert color, I think Jeep offered a Desert Sand color OEM. Most of those paints can be sprayed by the home gamer with good prep and basic equipment.
"In the end...It's all Hack."
HackFabrication is offline
post #5 of 7 Old 01-30-2014, 06:22 PM
strvger01
1966 CJ5
use a satin finish paint. hides the scratches and imperfections very well. buy a quart or two, then just a couple of spray cans of the same color for touch ups after trail riding. mine has held up very well for over 5 years now. it's on my ranger pu. i will be using satin paint again this summer for my cj5. lots of colors available in satin.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #6 of 7 Old 01-30-2014, 06:30 PM
waterdowg
When I get to painting mine I plan on use paint from Tractor supply. Only about $35 a gallon. You can buy hardener which will reduce the dry time dramaiclly. Stuff is tough. It also comes in spray can so you can touch it up. I plan to use the color International Harvester White which is actually Tan
waterdowg is offline
post #7 of 7 Old 01-30-2014, 06:41 PM
locohosa
If you want CARC without the insane CARC costs, read through this thread: LINK I aint done it personally on my M35, but I have seen the results. Its pretty close.
1996 Dodge Ram Cummins, 5.9L, NV4500, 4x4
1955 M35A2
1984 CJ7 4.2 T176, on 33s
locohosa is offline
