Advice for MUD build - JeepForum.com
post #1 of 19 Old 05-14-2009, 07:08 AM Thread Starter
Olrev
1981 CJ7
Hey guys, new fella from Alabama here, love the forum. I'm looking for some advice on helping my CJ get through the mud (better than it does). I recently joined a hunting club with lots of flat, swampy, slippery frog holes. It's not terribly deep mud but we do have the occasional flood that leaves 2foot of water on top of everything. Fortunately, there are plenty of trees to grab a hold of.
What I've got: 81CJ7 (had her since '86), 258 built up a bit, widetrack axles 3:31 gears, 30 open up front and 20 with traclok (or no-lok) in the rear. 3" springs and 33" A/T tires, 176 4sp tranny and 300tcase. I don't want to build a mud-bogger, but I'm sure my jeep has got to be better than a 4wheeler. And I like to be able to drive it to the hunting club (60miles).
So...opinions on how you would take her to the next level? Keep in mind the stimulus package hasn't stimulated me yet so I'm poor-boying everything...just pretend I had 2500-3k to spend (as my wife laughs in the background). I honestly don't want to go much bigger than 33" tires. Lockers? LimSlips? Tires? Any other advice? Thanks.
http://www.jeepforum.com/gallery/data/4/IMGP2142.JPG
Olrev is offline
post #2 of 19 Old 05-14-2009, 07:15 AM
jbach
how about an aussie locker in the front and some M/T tires. that should greatly enhance your traction offroad without suffereing driveability. $250 for the locker up to $1K for the tires.
jbach is offline
post #3 of 19 Old 05-14-2009, 08:12 AM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Lockers ( i agree on the aussies, ive had several and loved them)
Superswampers....Maybe some TSL radials or truxus tires?
A GOOD winch (even if you cant make it you can pull yourself though
and of course a winch bumper to put it on along with a good rear bumper so you have good recovery points.
thats about all i can think of unless you want to go to bigger tires.
Arcticcat843 is offline
post #4 of 19 Old 05-14-2009, 08:22 AM
JeepnBlake
If you're doing mud, boggers are the way to go.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #5 of 19 Old 05-14-2009, 08:23 AM
Rollbar
1984 CJ8
Mini spool in the rear 100bucks, Twin stick the T-case and a mini spool up front for a hunt buggy, if not an Aussie up front. Go w/the skinny tire (BFG M/T-R) to get down and dig. 3:31 is a good set up and I use that set up. Tera-low kit may help cause gearing is what it's all about.
<----Click
<---- Click
Rollbar is offline
post #6 of 19 Old 05-14-2009, 09:05 AM
jeepskate
Originally Posted by Olrev View Post
A/T tires,
That's like bringing knife to a gun fight I think you already know what your first/main upgrade is
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #7 of 19 Old 05-14-2009, 09:18 AM
Arcticcat843
dakuda is a god
1980 CJ5
Ive seen several people try to run a mini spool in the rear end of a vehicle on the street and it never ends well....Last one i seen only made it a month before it totally destroyed the rear end. And it was installed correctly. When they write "only for dirt track use" on the box i guess they mean it.....
Oh and if you are going to drive it 60 miles then wheel it, i would not buy boggers....I have them, they are AWESOME in the mud but they melt off when driving on the road, they dont balance at all and they are VERY loud (we put them on a soft top TJ and you couldnt even talk to the passenger they were so loud)
post #8 of 19 Old 05-14-2009, 09:20 AM
74CJMatlock
1974 CJ5
Some of this depends upon whether you're driving alone or in groups (or at least on a well-traveled road). A winch will get you out of the hole you're in, but won't solve the underlying problem of not being able to get through the mud. I'd seriously consider one if I were driving alone along fairly deserted tracks, but not worry about one so much if I was in a group or could count on somebody coming by (in something larger than a 4-wheeler) within half an hour of my getting stuck. Mud tires will be your best upgrade. Most mud terrain tires will be a good upgrade over A/Ts. TSLs would be much better, and Boggers best yet. It all depends upon how much tolerance you have for the reduction in street performance. A locker in conjunction with any of these tires will make them work much better. Personally, I'd do tires first, a locker (or two) second, and a winch as a Christmas present in the future.
1974 CJ-5
locked front and rear
74CJMatlock is offline
post #9 of 19 Old 05-14-2009, 09:42 AM
jp360cj
1977 CJ7
Mud tires should be your first upgrade. Even with open diffs, I've been able to get through more mud with my BFG MTs than my buddies with limited slips and ATs. If it were me, tires first, then lockers if needed.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #10 of 19 Old 05-14-2009, 10:10 AM Thread Starter
Olrev
1981 CJ7
All good stuff. I do have the twin shifter on my 300 and tires are absolutely on the upgrade list. I like the skinny tire idea, been looking at the narrow SS 34x9.50 from interco. I've got a 9k Pierce winch also.
Olrev is offline
post #11 of 19 Old 05-14-2009, 02:37 PM
burkerice07
1979 CJ5
You will need a Winch or a come along.... An warn winch cost somthing like $800.
I bought a 2 ton come along a Lowes for 50 bucks, and i have used it successfully to free myself from mud at least 20 times.
burkerice07 is offline
post #12 of 19 Old 05-14-2009, 02:40 PM
Rollbar
1984 CJ8
HF Winch-$299.00 bucks w/mounting plate and pulls SLOW all day.
<----Click
<---- Click
Rollbar is offline
post #13 of 19 Old 05-14-2009, 08:11 PM
ReconRabbit
1983 CJ7
Don't mean to start the fight but I've always had better luck with my 33-12.50's for the float factor. A jeep is generally light enough you don't have to find the bottom in the goo.
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline
post #14 of 19 Old 05-14-2009, 08:22 PM
Rollbar
1984 CJ8
Agreed, I run 33 12.5's on my other Jeep & 10.5's on Peaches jeep. I can really tell a difference on flotation. some times it's good/bad, depending on the terrain U want. No problem here, it just feels good to hit the bottom sometimes
<----Click
<---- Click
Rollbar is offline
post #15 of 19 Old 05-14-2009, 08:50 PM
yoopercj5
1978 CJ5
I run 33x1250 Dayton timberlines M/T. Work great and only about $150 each. They fold up good on the road. Had a set of them on my old F150. got 40,000 out of them.
yoopercj5 is offline
need advice! CJ engine/trans swap or build? jcberm Jeep CJ Forum 6 04-20-2016 02:41 PM
CJ-6 Build Plan - Any advice? Agar426 Jeep CJ Forum 12 02-08-2010 07:41 AM
Planning a DJ5 build up need experienced advice Shaboinka86 Jeep CJ Forum 0 04-09-2009 02:31 PM
1980 CJ7 offroad build advice jeep6959 Jeep CJ Forum 1 03-19-2009 12:30 AM
CJ5 Build advice skywalker2117 Jeep CJ Forum 8 02-03-2009 04:24 PM
