Additives that perform - Page 2 - JeepForum.com
post #16 of 22 Old 03-12-2010, 12:36 PM
deadeye
1983 CJ7
Originally Posted by heckyl View Post
Been testing - LS1 Performance Information read this thread. i've been using this in a tbi350,3.8 v6, and amc360 for about a year. all of them run smoother, get better milage, and the valve covers and plugs in the 350 look like new. good luck
I know a few people who have tryed this, it really works, and it's cheap.
83 CJ7, 350 TBI, TH350, Dana 300 twin stick, Dana 44 E-locker, Ford 8.8, Detroit, 4:10 gears, 35x13.5x15s
"Just Exchange Every Part"
deadeye is offline
post #17 of 22 Old 03-12-2010, 12:45 PM
CJ Chet
I tried Z-Maxx in mine, and there does seem to be a little more engine response. But on another note, I rubbed down the top of my welding table with it after heating it up real good with a space heater and there hasn't been a lick of rust on it for three years!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #18 of 22 Old 03-12-2010, 09:08 PM Thread Starter
RustyRenegade
1980 CJ5
We use that chevron stuff too sometimes. Not sure that it works but we go through a fair amount of it.
RustyRenegade is offline
post #19 of 22 Old 03-12-2010, 09:20 PM
CJ Chet
The local Ford dealer recommended it for my wife's Mustang. Seems to do the job.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #20 of 22 Old 03-13-2010, 06:13 AM
twmattox
Originally Posted by JeepHammer View Post
I see a bunch of 'Hub Bub' made about the zinc levels in oil...
Nothing to it I can see.
No failures breaking in new cams, no cold start wear beyond what you normally see.
Just a marketing ploy by the guys still pumping zinc in their oils.
I can't verify that there are significant issues with the lack of ZDDP...but, can say that when I emailed the major oil manufacturers, they all indicated that they have recently (in the last couple years) have significantly reduced the amount...but "it should still be safe for flat tappet engines". Personally, it is worth an extra $2 an oil change to add a little cushion...
twmattox is offline
post #21 of 22 Old 03-13-2010, 06:43 AM
skclark
1982 CJ7
Originally Posted by frank c View Post
I've been using Marvel Mystery Oil for years in all my vehicles, in the gas and every 3rd or 4th oil chg. I add some in place of a little oil.
I've got about 120,00 miles on one of the engines with this routine just pull the oil cap an look inside you won't believe the difference from another engine without having used it, no accumulation of sludge to be seen.
I was one of the many people who developed a lifter tick after an oil change. I just delt with it for a month or two hoping it would go away. Then after reading about people using Marvel I gave it a shot. What a difference! Ticking went away and all is good! I realize most of the "Mechanic in a bottle" stuff is just a short term fix though.
I use Rotella T oil in all my vehicles (dirt bikes too). I have noticed Rotella really cleans out the motor. Especially on a neglected motor like my 27 year old 258.
I recently decided to try the high mileage oil in my wife's 120k mile truck. I don't see any difference but supposedly it helps with old seals so I figure what the heck.
skclark is offline
post #22 of 22 Old 03-14-2010, 08:03 AM
Bubba Ray
I use Rotella oil and tried the seafoam. Big diff? No. Small diff? Maybe with the seafoam it cleaned some junk from the worn 180,000 mile 258. Oil pressure still very low but still running.
Bubba Ray is offline
Transmission oil additives tumbleweed58 Jeep CJ Forum 5 10-30-2009 12:06 AM
