Additional fuel filter ? - JeepForum.com
post #1 of 7 Old 01-10-2010, 06:51 AM Thread Starter
kmm
Was thinking on adding an additional fuel filter set up. This is on a stock 1979, 304 engine. Was wondering about placing a filter between tank and fuel pump. Currently has stock filter after fuel pump between carb. I guess there is also something in tank?(stock 15 gal.)
Is there any benefits or downfalls to doing this? If beneficial can anyone recommend a type of filter for this? Is inline ok or a cannister type better?
Also has anyone else done this? Any pictures of set-ups?
Thanks
kmm is offline
post #2 of 7 Old 01-10-2010, 06:58 AM
Mike Romain
Your pump is a suction style of pump that is supposed to have a filter on it's pressure side only. Having a filter on the suction side can be problematic when the filter gets old. The pump will have to work very hard to try and suck through this old filter. Pushing pressure through an old filter is easier on it and normal.
Mike
Mike Romain is offline
post #3 of 7 Old 01-10-2010, 07:53 AM
jfwireless
1976 CJ7
You should already have a sock type filter on your fuel pick in the fuel tank.
What Mike said X2
Jim
jfwireless is offline
post #4 of 7 Old 01-10-2010, 08:36 AM
OlivergreenCJ7
Thanks
If the reason is because your getting sediment in your gas. It might be time to drop and flush the gas tank out or just replace it.
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline
post #5 of 7 Old 01-10-2010, 10:34 AM
desert_driller
1983 CJ7
I agree with Mike, jfwireless, olivegreenCJ
Thanks
I too was thinking that the filter was letting stuff get into my carb so I cut it open to see what magic goes on in that metal cylinder. Looks very substantial to me.
Just in case, I added this separator before the fuel pump. We will see how it works out.
I also put a clear plastic fuel filter between the carb vent line and the charcoal canister. Just in case any charcoal was coming in the back way.
As you can see, I put filters in all of the lines.
83 CJ7, Nuttered, 2" lift.
desert_driller is offline
post #6 of 7 Old 01-10-2010, 03:27 PM
CJ258
1974 CJ5
Years ago I had a '73 Scout II with a fuel filter just after the tank. It looked like an aftermarket oil filter relocater arrangement. Frame mounted with a spin on oil type filter. I changed it once and cut it open to find it full of rust and fine sand from the tank.
CJ258 is offline
post #7 of 7 Old 01-10-2010, 05:54 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Another reason to not have the filter in front of the pump is vapor-lock. The restriction of the filter with the pump trying to pull fuel thru it causes more of a negative pressure on the fuel.
You can make water boil are room temperature with enough vacuum. Same with Fuel. Why aid that nasty vapor issue because of mistrust of the current filter you have on it.
If anything, put another clear plastic one after the stock one. This will let you see easily if anything is getting thru the first one. If there isn't, remove the extra restriction of flow to the carb.
Rick
Cutlass327 is offline
Fuel filter/vapor-lock/fuel starvation...help please. hh65flyer Jeep CJ Forum 1 07-22-2009 03:05 PM
84 CJ fuel filter 79cherokee Jeep CJ Forum 0 05-19-2008 08:21 PM
Fuel Filter diamatron Jeep CJ Forum 1 04-16-2008 09:00 AM
Fuel filter tmoreau Jeep CJ Forum 1 04-11-2007 03:31 PM
Fuel Filter MudLover Jeep CJ Forum 7 07-10-2003 08:08 PM
