Adding shoulder belt-Who sells a bung for 2 1/4 pipe? - JeepForum.com
post #1 of 7 Old 05-05-2013, 02:49 PM Thread Starter
pman
I'm going to add shoulder belts to the CJ5. I'll need to drill a hole and insert a bung, but the only ones I've found from Poison Spider and Summit Machine are for 2" or less O.D. Pipe, and mine's 2 1/4. Anyone know a good source for these?
I know I can probably just drill a hole through the rollbar and insert a grade 8 bolt/nut to secure the strap mount, but is this really the safest option? I like the idea of a welded bung and threading the bolt into that (at least in theory it sounds more structurally sound. Am I over thinking this?
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #2 of 7 Old 05-05-2013, 04:51 PM
82JeepCJ7
1982 CJ7
Go down to the local hardware store and get some 1/2" black iron pipe. I picked up a couple of 6" nipples. I drilled my hole in the roll bar tube, then welded in the pipe. I then cut the pipe off with a grinder just above the welds. Cleaned them up, chased them with a 1/2" bit and they work perfectly. Cost about $3 total.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 7 Old 05-05-2013, 05:36 PM Thread Starter
pman
Thanks '82! This is a great idea. Dumb question-what is a 6" nipple?
pman is offline
post #4 of 7 Old 05-05-2013, 06:31 PM
roadhog304
1973 CJ5
Nipples are short pieces of pipe used for plumbing, gas lines, etc. You can pick them up at any hardware store. They come in many different diameters and lengths. You will want to get one about for gas line because it is black pipe and easily weldable.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #5 of 7 Old 05-05-2013, 06:37 PM Thread Starter
pman
Ahh! Thanks Roadhog. Hope the helpful hardware woman doesn't mind if I ask to see them.
pman is offline
post #6 of 7 Old 05-05-2013, 06:58 PM
skizriz
1978 CJ7
skizriz is offline
post #7 of 7 Old 05-05-2013, 08:47 PM
82JeepCJ7
1982 CJ7
I wouldn't WANT to ask so see some 6" nipples from some of the hardware chicks around here....
