Add another battery hold down on factory cj battery tray ? - JeepForum.com
post #1 of 11 Old 10-21-2013, 03:21 PM Thread Starter
agear
Has anybody added another battery hold down on their factory battery tray ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 11 Old 10-21-2013, 03:32 PM
83vert
1982 CJ7
I added two j hooks and the hold down. I just drilled a 1/4" hole in the back of the tray and used the existing hole in the front
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #3 of 11 Old 10-21-2013, 05:51 PM
skizriz
1978 CJ7
It's a replacement tray, but this is how I secure mine. I bounce around in the rocks alot, and didn't trust the little clamp at the base.
skizriz is online now
post #4 of 11 Old 10-21-2013, 06:16 PM
82JeepCJ7
1982 CJ7
Mine is made from flat bar and totally holds the battery in, no matter how many times I roll it.....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 11 Old 10-21-2013, 06:22 PM
skizriz
1978 CJ7
That's where I got the idea for mine. Your picture got me thinking (which is usually a bad thing), and I made mine the next day.
post #6 of 11 Old 10-21-2013, 07:07 PM
82JeepCJ7
1982 CJ7
Oh gawd.....
post #7 of 11 Old 10-21-2013, 08:57 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I added an extension for a second battery and a hold down to my factory tray.
Matt
Matt1981CJ7 is offline
post #8 of 11 Old 10-22-2013, 07:25 AM
John Strenk
John Strenk's Avatar
1976 CJ5
How embarrassing,
I added a couple bungee cord....
But it added the needed shock retention needed when I slam into a frozen snow bank to move it back a little for more room.
Without it, the lip would bend and bend until the battery came loos and landed on my starter. Since I put the Bungee cords on, I don't get any bending anymore.
And the batteries seem to last longer also.
Maybe I'll try to come up with a spring or rubber loaded retention system.
Maybe a battery warmer also...
John Strenk is offline
post #9 of 11 Old 10-22-2013, 02:58 PM Thread Starter
agear
Awesome thanks. A bracket from battery tray to radiator support rod and from that a bracket down to where the clamp bolted on. Thats what I wanted to see.
agear is offline
post #10 of 11 Old 07-31-2014, 10:44 AM
turbogus
1978 CJ5
Hey Matt how tight the clearance between the J bolt and the fender lip? Did you have to cut clearance?
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #11 of 11 Old 07-31-2014, 10:57 AM
Mike Romain
I used to live where it is -40 for months and we used 2 different ways that both worked. One was the battery warmer blanket they sell and the other was a 2a trickle charger. Or a block heater by itself or in combo. Block heater is pretty much a must at -40. The block heaters were usually on a timer if you knew you weren't going to use it overnight, 3 hours works and saves a lot on the power bill.
Lots of folks even brought their batteries in at night.
Mike
Mike Romain is offline
