Quantcast Add another 40 hp to your 4.2 6 Banger! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Add another 40 hp to your 4.2 6 Banger!
Poison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big RedRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 12-27-2006, 09:22 PM   #1
SupaJosh
I found this awesome write up on how to put more horse power maybe 40, he says, in my 4.2 by putting a 4.0 head on it and you don't have to rip the whole motor out either! Relatively simple I think...since I just rebuilt a dakota v-6.
http://www.geocities.com/035jeep/40L.html
The good thing is its fairly cheap mod compared to the hp out of it!
Good luck I will try it in about a month! I just got my 84 Cj7 back on the road!
SupaJosh is offline   Reply With Quote
Old 12-27-2006, 11:23 PM   #2
jeepskate
People have been doing this for several years now. Probably the best site for info is the 4.0 swap forum (covers the head as well as the whole engine) over at www.cjoffroad.com
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 12-28-2006, 11:13 AM   #3
AMC Power
I am currently rebuilding a 4.2 and I did not go with the 4.0 head because I wanted to put a 4-barrel intake on it as well as a dual outlet header. I don't think you can do that with the 4.0 head.
AMC Power is offline   Reply With Quote
Old 12-28-2006, 11:23 AM   #4
gosupes
Bet me.
Although the headers would have to be custom as no one makes duals for the 4.0 head. I wouldn't do the dual header because the 258 likes a little more backpressure for the low end grunt.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
gosupes is offline   Reply With Quote
Old 12-28-2006, 12:21 PM   #5
jadams68
I did this mod a year ago.
http://www.bustedjeep.com/projects/rebuild.asp
I used to own a CJ....:-(
AIM: Qsting68
jadams68 is offline   Reply With Quote
Old 12-28-2006, 12:52 PM   #6
SupaJosh
Originally Posted by jadams68
Nice and what were the results? More horse power? Run better? Better gas mileage? and what was it? Did you do the fuel injection?
Old 12-28-2006, 12:56 PM   #7
jadams68
- More power yes... I never put it on a dyno to get an exact measurement in horsepower tho.
- Fuel economy...not really because I have 35" tires with 4.56 gears and any fuel economy gained would be negligable.
- The head won't make it run better, just gives you power. To really make significant gains with a 4.0L swap, you need to put a fuel injection kit on it. I did a TBI Howell FI kit, however the real performance gains are made by a multi-port fuel injection system.
I love the results. It's as reliable as any modern vehicle. I never stall and it starts right up no matter how cold it is.
AIM: Qsting68
Old 12-28-2006, 07:57 PM   #8
BIGM
For anyone who has done the 4.0 head conversion, what did the head and parts cost you?
BIGM is offline   Reply With Quote
Old 12-28-2006, 08:10 PM   #9
GPER
1979 CJ7
I bought my 4.0 head for 125 bucks then about 350 to redo the head, drill, tap and plug the water jackets. Then Mopar rapes you for the valve springs to go with a torquer cam. They were 300 bucks with a Jeep Tech's discount. Crane springs were like 80 bocks but they didn't have the retainers and locks to fit.
GPER is offline   Reply With Quote
Old 12-29-2006, 08:39 AM   #10
gosupes
For me, it cost $250 for a rebuilt head and my 258 head for a core. I milled the jackets at work, it took about 45 minutes for setup and 20 minutes to mill the jackets for freeze plugs.
Old 12-29-2006, 08:53 AM   #11
Fatman
2008 CJ7
Anyone use these guys for their heads?
http://www.cylinder-heads.com/
the 4.0 head water jackets are sealed new valves, seats, 3 angle job
http://www.cylinder-heads.com/store_items_view.asp?itemid=16135
"Chrysler Conversion 6 cylinder. Fits years 98-99, 4.0 ltr. Casting number 7120"
Fatman is offline   Reply With Quote
Old 12-29-2006, 12:26 PM   #12
BIGM
Some of the links that give info on the conversion are dead. I have done some googling but nothing more informative. Anyone have any other good links? I was also wondering about http://www.cylinder-heads.com/ Looks like a good deal with the water jackets done.
Old 12-29-2006, 01:45 PM   #13
badge1236
1978 CJ7
Does this do anything to the realibility of the engine? How long will it last? Also, what year heads would fit on a '78 block?
'78 cj-7, 258, twin stick dana 300 transfer case, NV3550 transmission, scout d44 axles with detroit truetrac, 4.09 gears, black diamond 3.5 inch lift. The rest is yet to come.
badge1236 is offline   Reply With Quote
Old 12-29-2006, 02:35 PM   #14
jadams68
I bought mine from Hesco which is probably the most expensive route, but I wanted it done right.
The link above to Clearwater cylinder head is a buyer beware. I first went with them and the head that was sent was defective. They gave me my money back, but I don't recommend them.
A 1978 block has the 1/2" head bolts which is great. Any 4.0L head with casting 7120 or 0630 will work. Mine is from a 1996 Cherokee.
AIM: Qsting68
Old 12-29-2006, 03:24 PM   #15
gosupes
Hesco does have that aluminum head for just over $1800 for those with deep pockets.
Glock Forum
