Adapting stock air cleaner to Weber carb - JeepForum.com
post #1 of 13 Old 11-30-2008, 10:52 AM Thread Starter
WolfDawg
When the guy that installed my Weber did so, he stripped all the old air cleaner stuff out...I'm getting more and more convinced that the lack of this stuff working right is causing my gas fume problem....
My question is how do I adapt the original stock air cleaner stuff to work with my new Weber 32/36 carb?
Thanks in advance!
WolfDawg
WolfDawg is offline
post #2 of 13 Old 11-30-2008, 10:55 AM Thread Starter
WolfDawg
Ok...got home with the Jeep....was actually a nice ride in the rain..I guess the moisture in the air helps dissipate the fumes.
At any rate, I found two canister looking things in the Jeep, one on the left and one on the right....neither one appears to have any connections to the carburetor at all....one has NO hoses whatsoever, and the other has a hose that isn't attached to anything else, one place that looks like it should have a hose and doesn't, and one hose that goes back under the firewall...not into it, just routes up under the body towards the back of the Jeep.
Whichever one is the fuel vent/charcoal canister, it ain't hooked up right....
I want to try and reinstall all the original air cleaner assembly stuff...how do I make all that stuff work with the new Weber 32/36 carb?
I'll post this as a new post as well....and will try to get up some pics of all this when it stops raining.
Thanks again!
WolfDawg
WolfDawg is offline
post #3 of 13 Old 11-30-2008, 12:27 PM
Mike Romain
The charcoal canister is the one on the drivers side with the line running back to the gas tank.
The small top vacuum nipple goes to the CTO valve and the other side of the CTO goes to the spark ported distributor vacuum line. It can use a T fitting to join them.
The line below the small one on the round valve is the purge that goes to a T fitting in the PCV line. The other one was for the carb float bowl vent and can be plugged and the last line goes back under the firewall to the gas tank.
Here is a good site that will help you ID most of the stuff:
http://home.sprynet.com/~dale02/
Mike
Mike Romain is offline
post #4 of 13 Old 11-30-2008, 06:38 PM
wellmax
wolf,
I installed a webber carb on my 1984 jeep cj-7.
the webber carb is set up to use the air clearner assembly that comes with the carb.
your tappet cover should have two holes in top of tappet cover, one front and one rear
the one in front should have a line that connects to the vac line the goes into the vac side of carb or intake manifold and power brake boster.
the rear hole in tappet cover should have a line running to the bottom of your new webber carb air cleaner. Filtered air is drawn into motor through this hole and and fumes are sucked through pvc valve to vac side of carb or intake manifold.
That is the way mine is set up and I do not have fumes.
Good luck
wellmax is offline
post #5 of 13 Old 11-30-2008, 06:57 PM
keith460
Jeep. There's Only One
keith460's Avatar
Thanks in advance!
WolfDawg
I don't know where you purchased your Weber carb, but I got mine from these people and it came with an adapter to use the factory air cleaner.
http://www.carburetion.com/Weber/Dat...20/%20CHEROKEE
You have to raise your air cleaner assembly off the valve cover by 1 inch when using an aluminum cover and maybe more if using the stock plastic valve cover since the Weber carb is taller than the stock Carter BBD carb.
Here's some pics of it installed on my 258 I-6:
keith460 is online now
post #6 of 13 Old 11-30-2008, 09:15 PM
jeepskate
Pretty sure I've posted the part number for the adapter here before...should be able to find it using the search tool.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #7 of 13 Old 12-01-2008, 06:59 PM Thread Starter
WolfDawg
Hey, wellmax....
I just checked and I do not have two holes in the tappet cover for my Weber...just one...in the front...and the hose from it goes into what lookes like the PCV breather hole towards the back of the manifold cover. The hose running out of the PCV valve hole at the front of the manifold cover runs to a connector at the BASE of the carb, in the front of it, down where those aluminum adapter plates are.....but only the ONE hole in the tappet cover where the air filter sits....
So, what's up with that?
WolfDawg is offline
post #8 of 13 Old 12-01-2008, 07:00 PM Thread Starter
WolfDawg
That adapter plate looks like what I'm wanting to try and do, but my carb is just the K-551 32/36....not the "S"....don't know if that would work or not....any ideas?
Thanks!
WolfDawg is offline
post #9 of 13 Old 12-01-2008, 09:04 PM
mcmud
1983 CJ8
That 'S' represents the kit with the stock adapter added but the usual little breather omited. The K-551 Kit you have is I think the DGEV series 32/36 like keiths carb. in the pic. you should be able to find the adapter at most if not all the Weber sites.
mcmud is offline
post #10 of 13 Old 12-01-2008, 10:29 PM
wm69
I've got a 32/36 with that adapter, so they make one that will work with your carb. Jeep is 4 1/2 hours from me currently so can't help you out with a part #.
wm69 is offline
post #11 of 13 Old 12-05-2008, 08:05 PM Thread Starter
WolfDawg
I just hope I can order the part without ordering the entire kit....
THX, guys!
WD
WolfDawg is offline
post #12 of 13 Old 12-05-2008, 10:02 PM
jeepskate
Like I said, I posted the p/n here before (when I bought my adapter)...a search should turn it up. I made a point of posting the info here so that it could be found by others. I found the place I bought it from originally by Googling.
post #13 of 13 Old 12-05-2008, 10:09 PM
jeepskate
Here ya' go: http://www.jeepforum.com/forum/f8/weber-32-36-38-air-cleaner-adapter-181705/
Weber with stock air cleaner disa Jeep CJ Forum 12 02-26-2011 11:59 PM
Aftermarket air cleaner for 258 w/ stock carter carb cjkcj7 Jeep CJ Forum 1 08-16-2009 12:50 PM
Weber carb air cleaner assembly replacement jennandal Jeep CJ Forum 2 09-24-2007 09:51 AM
Adapter to use stock air cleaner with weber wm69 Jeep CJ Forum 2 07-07-2005 07:57 AM
Update Weber with Stock Air Cleaner disa Jeep CJ Forum 2 11-16-2004 04:55 AM
