Adapting 81+ Temp Sensor to 79 Gauge? - JeepForum.com
post #1 of 5 Old 08-14-2009, 03:00 PM Thread Starter
attworth
1979 CJ7
I'm using 81+ exhaust and intake manifolds on my 79 258. The later ones are coolant heated. I'm wondering how to run the coolant temp sensor. Here's a picture.
It has two wires, whereas the original sensor for the motor had a single wire. Unless this isn't what I think it is - in which case, what is it?
There is another fitting that looks similar to my original temp sensor which is on the back of the intake.
Thanks!
attworth is offline
post #2 of 5 Old 08-14-2009, 03:15 PM
CSP
Why aren't you using the original temp sensor?
You shouldn't have to change a thing in regards to the temp sensor just because the newer manifolds are used.
The switch in your picture is the one that is used by the computer to tell the computer controlled BBD carb to go to closed loop. It isn't used for the temp gauge.
http://home.sprynet.com/~dale02/coolant.htm
The other sensor you're seeing is probably the one that controls the electric manifold heater.
http://home.sprynet.com/~dale02/manifold.htm
CSP is offline
post #3 of 5 Old 08-14-2009, 03:21 PM
xeroOTG
If its a temp sensor, one is a ground, the other signal. On GM style sensors, yellow is signal, black is ground. It does look like a temp sensor to me, but im not 100%.
My jeep gives a whole new meaning to the phrase, Just Empties Every Pocket!
1975 Jeep CJ5 258 TBI EFI, T-18, D-20, D44 rear, 4.11.
1992 Jeep Cherokee 4.0L, AW4, NP231 October 2009 - August 2012
1998 Jeep Cherokee 4.0L, AX15, NP231 - August 2012
xeroOTG is offline
post #4 of 5 Old 08-14-2009, 04:23 PM
OMR
The temp sensor for the gauge is on the back corner (drivers side) of the head.
The other two sensors are as CSP said -
Mark
'86 CJ7 - 258 - Howell - 'Rushed' - 2.5" sl, 1" bl - T5 - d44 rear - 33 x 12.5
OMR is offline
post #5 of 5 Old 08-14-2009, 04:47 PM Thread Starter
attworth
1979 CJ7
Thank you, that's kind of what I was thinking but wanted to make sure.
attworth is offline
Temp gauge and fuel gauge quit Foulplay Jeep CJ Forum 11 11-09-2012 09:43 AM
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 05:49 PM
coolant temp sensor and gauge question caleb7mm Jeep CJ Forum 2 05-06-2009 04:28 PM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 12:41 PM
Fuel gauge, temp gauge HEADSPACEXXX Jeep CJ Forum 5 04-03-2008 05:26 AM
