adapter for double cardon joint? - JeepForum.com
post #1 of 7 Old 09-02-2008, 06:14 PM Thread Starter
muddyjeepguy85
1983 CJ7
I have a 83 cj7 and have put in my SOA lift which went well up intil this point pretty much. I bought a front driveshaft off a XJ with a double cardon joint to take place of my old and now way to short stock rear one, but at the end with the cardon joint the strap holes dont line up with the stock yoke of the transfer case. Is there an adapter for this or some other solution? thanks.
muddyjeepguy85 is offline
post #2 of 7 Old 09-02-2008, 06:44 PM
NH2112
You'll either have to get an "adapter" type U-joint, or get a driveshaft/transmission shop to make or order you a new yoke. The latter is my recommendation because you may not be near a place that carries the special U-joints if & when it goes.
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
post #3 of 7 Old 09-02-2008, 06:54 PM
gojeepin
1983 CJ7
You can find the CV shaft (double cardan) yokes at Tom Woods or sometimes on eBay. Keep in mind there are yokes of different depths (length).
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 7 Old 09-02-2008, 07:10 PM
jeepskate
Should be a 26-spline 1310 double cardan yoke...I just bought one from **** off Ebay for $40 last week...you don't need anything custom, this is an off the shelf part that any driveline place can get for you...it's a standard Spicer part (I used to have the part number written down somewhere) and you could actually use the one off the XJ the shaft came from. You'll be switching from straps to u-bolts.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #5 of 7 Old 09-03-2008, 04:29 PM Thread Starter
muddyjeepguy85
1983 CJ7
is it possible to get a yoke that would fit my stock output shaft on my TC spline that would bolt directly to the double cadon.
post #6 of 7 Old 09-03-2008, 04:52 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yeah.. just look for a 26 spline CV yoke. Stock XJ yoke will work, as will a front Quadratrac yoke.
BESRK is offline
post #7 of 7 Old 09-03-2008, 05:27 PM
jeepskate
Uh, didn't you read my post?
Double the fun, Double the trouble bigjoe Jeep CJ Forum 99 09-14-2014 01:20 PM
double post wrongway92407 Jeep CJ Forum 0 12-31-2009 09:14 PM
has anyone rebuilt a double cardan joint 79-CJ-7 Jeep CJ Forum 1 06-18-2009 05:41 PM
double cardan cv?? neatocj Jeep CJ Forum 15 07-30-2008 05:06 PM
Advance Adapter Chevy Bellhousing adapter thiswebs4u Jeep CJ Forum 6 11-28-2007 07:25 PM
