Adam's 1979 CJ5 Frame-up - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Adam's 1979 CJ5 Frame-up
Ruffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wd
Unread 02-08-2013, 12:10 AM   #91
acgcoug
1979 CJ5
This is an older pic, but this was all the crap that I fought when taking the body mounts off. There's only 4 intact bolts in the picture because the other 7 either snapped off or were cut off and still attached to the tub.
_________________________
Adam's 1979 CJ5 Frame-up build: http://www.jeepforum.com/forum/f8/ad...me-up-1363422/
acgcoug is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 05:54 AM   #92
rixcj
rixcj's Avatar
1979 CJ5
Nice repair work, Adam! I agree completely, that we'd be lost without cutting wheels!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 06:26 AM   #93
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Adam,
Sorry if this has been asked and answered already, but what welder are you using on the sheet metal, and what settings seem to work best?
Your welds look a lot cleaner than what I've been able to achieve with my Lincoln 140 MIG welder.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 07:36 AM   #94
Renegade82
Renegade82's Avatar
1982 CJ7
Originally Posted by acgcoug View Post
Wipe them down with a little Armour-All and they'll be good as new!
You did better than me. I was only able to get 1 bolt out. All the others either stripped, twisted, or snapped off. The hardest two were the ones on the crossmember above the gas tank. Not much access for the sawz-all.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 09:08 AM   #95
acgcoug
1979 CJ5
Originally Posted by Bojon View Post
I thought I was being fairly thorough! You are going above and beyond! Great looking work
Thanks Jered!
Rich
Thanks Rich!
Originally Posted by Matt1981CJ7 View Post
Adam,
Matt
Here's my set-up, Lincoln Handy Mig with shielding gas. I only use Lincoln .25 wire from Home Depot, better than the Harbor Freight wire in my opinion. It's a total budget/starter welder, but the thing just works like a champ, so easy to use. It has 4 heat settings, and I usually have it set at Low/2 for thin metals, and either High/1 or High/2 on the thicker stuff. Kind of depends on how big of a gap I have between repair patches. The welder's rated up to 1/8" steel, but I think it can go a little thicker. I wouldn't use it on making custom bumpers or anything, but it's strong enough for any frame repairs, and perfect for sheet metal. I got it on-line from Home Depot, check out the link for all the details.
http://www.homedepot.com/webapp/wcs/...a#BVRRWidgetID
Lol, so a little spit and shine won't make these as good as new? Darn, I was hoping to save a few bucks by re-using all this stuff. Fortunately the two above the gas tank came out the easiest for me.
Unread 02-08-2013, 09:45 AM   #96
Matt1981CJ7
1981 CJ7
Adam, thanks, your welder is very similar to mine.
I guess I just have to experiment with the settings some more....
Matt
Unread 02-13-2013, 01:52 PM   #97
2girlsAndaGuy
1979 CJ5
Adam, I haven't seen your thread in a while. Your tub is really coming along nicely, you are taking detail to a hole new level on this one.
[COLOR="Blue"][URL="http://www.jeepforum.com/forum/f8/project-ioh-79-cj5-refresh-1360217/"]My 79 CJ5 Build Thread[/URL][/COLOR]
David
2girlsAndaGuy is offline   Reply With Quote Quick reply to this message
Unread 02-13-2013, 04:32 PM   #98
acgcoug
1979 CJ5
Thanks man, I'm trying and slowly making progress.
I'm excited for your build, you should be up and running pretty soon. Try and get some video of your first start, that's always a fun one to remember.
Unread 02-13-2013, 05:18 PM   #99
acgcoug
1979 CJ5
Need some advice.
I'm trying to decide between rubber or poly body mounts?
I'm leaning on getting the rubber because I've heard they ride a littler softer. Any truth to this?
Unread 02-13-2013, 05:29 PM   #100
Matt1981CJ7
1981 CJ7
Adam,
I just replaced my worn-out original rubber mounts with poly, and can honestly say I didn't notice a bit of difference.
I think the suspension has more to do with ride quality than the material of the mounts.
Matt
Unread 02-13-2013, 07:39 PM   #101
Renegade82
Renegade82's Avatar
1982 CJ7
I would tend to think the rubber ones do give a slightly softer ride, but I don't know if it's enough to be a factor. I decided to go with the poly ones with an extra inch built in, mainly for their durability and resistance to the elements. They outlast the rubber ones. Mine were still the originals and between them and their mounts, both were shot so I won't even be able to compare the two once mine is together.
Unread 02-14-2013, 12:02 AM   #102
acgcoug
1979 CJ5
Thanks for your input guys, I ended up getting the Poly Energy Suspension Body Cab set:
http://www.quadratec.com/products/26057_1X_PG.htm
Durability ended up being my deciding factor.
Unread 02-21-2013, 12:47 AM   #103
acgcoug
1979 CJ5
I've been contemplating whether or not I needed to cut out my pillars. Turns out that it was a good decision to do so.
Doesn't look too bad from here, and there's no rot/holes on the exterior sheet metal:
You can already see the crud falling out just from cutting out the spot welds.
Underside:
Yikes, much worse than I expected. Definitely a good decision to pull them.
Sand blasting/cleaning up. The upper section wasn't as bad as it looks in the previous image, mostly surface rust. There were a few spots here and there where the metal was thinned out a bit so I hit those spots with my welder.
As you can see, no signs of rot on the exterior metal. Wouldn't have been long before rust bubbles started showing up though:
Outer patch:
Turned out nice. I also filled in all the screw holes from where the diamond plating was installed.
Cleaned up, sand blasted, and cut out the bad metal on the pillar.
Patched up pillar
Painted on some Por 15 to the backside of both areas and welded everything back together.
Now I have to get to the other side.
Unread 02-21-2013, 08:09 AM   #104
rixcj
rixcj's Avatar
1979 CJ5
A very worthwhile repair!
Rich
Unread 02-21-2013, 08:40 AM   #105
Matt1981CJ7
1981 CJ7
Adam,
Beautiful work, man.
Very few CJ owners tackle that repair in time. I'm glad to see you spared the Jeep logo.
Matt
