Adam's 1979 CJ5 Frame-up - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Adam's 1979 CJ5 Frame-up
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiFree Shipping on TIRES at KrawlOff-RoadSpartan Locker's at all time LOW exclusive from ROCKRIDGE
Unread 07-14-2012, 01:23 PM   #61
acgcoug
1979 CJ5
It's been a little bit since I last posted some progress pics, so here we go:
Moved on to the other side of the rear of the tub.
Just like the other side, this section needs cutout and replaced with new metal.
Backside:
Patch welded in (needs grinding still):
Constructing new body mount/box section:
Finished up. I will weld this piece on later after I clean up/sandblast some some areas on the rear of the tub.
Wheel housing brace removed and cleaned up. I will cut out and replace the bad sections later.
Backside of rusted/rotted section where the brace was mounted.
Topside:
Topside patch welded in:
Backside (still need to weld the folded section that meets the inner side of the tub, plus the spot weld hole that I drilled).
Topside mostly ground down:
Filling in holes from where the diamond plating was installed.
_________________________
Adam's 1979 CJ5 Frame-up build: http://www.jeepforum.com/forum/f8/ad...me-up-1363422/
acgcoug is offline   Reply With Quote Quick reply to this message
Unread 07-14-2012, 01:50 PM   #62
Skerr
WOW!! That's outstanding work!! You are all over it. I so hope my tub doesn't have the same symptoms when I get into it. Great detail.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 10:13 AM   #63
acgcoug
1979 CJ5
Still around guys. Life has been pulling me in other directions, but I'm itching and planning on getting back to the jeep soon...I hope.
Unread 01-08-2013, 10:16 AM   #64
WNC-84CJ7
I know what you mean! During the semester, I am off for 4 or 5 months at a time! I can't stop thinking about it though. Now, get back on that Jeep.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2013, 03:43 PM   #65
acgcoug
1979 CJ5
Had a little bit of time on my hands, still trying to finish up the valence and rear body mount sections. Getting close to welding the newly made nut/bolt cages, and then I will Por15 the inside of the valence section, and then weld the repaired valence back on.
Unread 01-10-2013, 06:34 PM   #66
Griffen24
1979 CJ5
AMAZING metal work! only wish i has some of your skills...
Griffen24 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2013, 07:41 PM   #67
commadore64
commadore64's Avatar
1980 CJ5
Dude... awesome body work... looks great!
1980 CJ-5
My build thread: http://www.jeepforum.com/forum/f8/bo...j-5-a-1290405/
"For evil to flourish, all that is needed is for good people to do nothing."
commadore64 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2013, 09:51 PM   #68
Skerr
^^^ What they said, Adam. Heck of a good job.
Kerrdog
Go Fish! <*////><
Unread 01-11-2013, 10:53 AM   #69
acgcoug
1979 CJ5
^^^Thanks Guys!
I've been contemplating making my own threaded square nuts for my body mount nut cages, but decided to stop by Fastenal to see what they had. None of the other hardware stores in town had anything that would work. This is what they had:
As you can see in the pic they are a tiny bit thicker than the original one, but they should work perfect because I made my nut cages slightly taller than the originals. I have 6 total of these darn things to remove, make, and weld on. Anway, so if anyone needs these little guys, check with Fastenal ($2.80 each).
Unread 01-11-2013, 11:24 PM   #70
rixcj
rixcj's Avatar
1979 CJ5
My hat's off to you! You are putting forth a Herculean effort to do a thorough tub repair! Nice metalwork!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 03:08 PM   #71
Renegade82
Renegade82's Avatar
1982 CJ7
I didn't realize they carried those. I had made mine from 1/4"x1 1/2" flat stock, then drilled and tapped them. Those would have saved me some time for sure. Nice job.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 04:39 PM   #72
waterdowg
^^^Thanks Guys!
Do you have part number or a exact name they go by?
waterdowg is online now   Reply With Quote Quick reply to this message
Unread 01-18-2013, 05:31 PM   #73
acgcoug
1979 CJ5
3/8"-16 Zinc Plated Square Attachment Nut for Concrete Spot Inserts
Fastenal Part No. (SKU): 49464
http://www.fastenal.com/web/products...l.ex?sku=49464
FYI, they had 2 slightly different looking ones in the same tub, the one stamped 3/8 (see pics) was slightly thicker and threaded much better (the ones I bought). If you visit the Fastenal store, make sure you take a body mount bolt to double check that they will thread correctly.
Unread 01-27-2013, 10:47 PM   #74
acgcoug
1979 CJ5
Installed the newly made body mount nut cages and was finally able to seal up the rear valence section.
Degreased, phosphoric acid etched (same as metal ready step), and applied 2 coats of Por 15 to the back of the repaired valence and the boxed section.
Spot welded
Ground down the welds
Unread 01-27-2013, 10:55 PM   #75
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Adam,
I think it may have been easier for you to weld up a new tub from scratch.
I'm enjoying watching your excellent work.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
