Adam's 1979 CJ5 Frame-up - Page 8 - JeepForum.com
 2Likes
post #106 of 252 Old 02-21-2013, 08:45 AM
2girlsAndaGuy
1979 CJ5
impressive work as usual Adam, seeing that makes me nervous what I ended up leaving behind my pillars. Time will tell I guess...
David
2girlsAndaGuy is offline
post #107 of 252 Old 02-23-2013, 11:00 AM Thread Starter
acgcoug
1979 CJ5
Ugh, I fired up the welder this morning and I'm out of shielding gas!
It's the weekend and I was planning on getting a bunch of metal work done. Praxair is closed on the weekends.
Yippee, yard work time.
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #108 of 252 Old 02-23-2013, 01:46 PM
Skerr
Ain't it a blessing to have yard work to do this time of year!? I know exactly how you feel about the gas!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #109 of 252 Old 02-23-2013, 02:25 PM Thread Starter
acgcoug
1979 CJ5
I hear ya, sure beats shoveling snow. Been there done that.
acgcoug is offline
post #110 of 252 Old 02-23-2013, 05:32 PM Thread Starter
acgcoug
1979 CJ5
Since I am out of gas for my welder I decided to strip off all the bondo on the passenger side of the tub.
At some point the previous owner got in an accident and crinkled the tub pretty good. I do believe a body shop did the repair work and did a decent job, but it appears that they went too heavy on the bondo. I should be able to straighten the metal out a little better with my hammer and dolly set, and hopefully use less body filler when I get to that job.
Pretty thick as you can see in the lower left corner of the pic:
Took me about 2 hours to grind all the bondo off with a wire wheel on my grinder.
acgcoug is offline
post #111 of 252 Old 02-23-2013, 05:36 PM Thread Starter
acgcoug
1979 CJ5
I also received a couple goodies in the mail today.
My poly body mounts and Moses Ludel's Rebuilder's Manual.
acgcoug is offline
post #112 of 252 Old 02-27-2013, 02:05 PM
Skerr
I would love a critique on the manual. I have heard nothing about it, but I've seen it out there.
I can't see the body work being an issue with your skill set. Looking forward to seeing your repair.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #113 of 252 Old 02-28-2013, 10:55 AM Thread Starter
acgcoug
1979 CJ5
Scott,
The manual will work nicely in conjunction with the FSM. There are nicely detailed write-ups, tips, and lots of photos on rebuilding the T18 tranny, dana 20 TC, axles, clutch work, and plenty more. The section on rebuilding engines is okay, but very good if you have a T18 transmission.
I'm only about half way through the book, but for someone that is learning the ropes on rebuilding a vehicle/jeep (like me) then I do believe it is a must read.
I bought a used, "very good condition" copy off of Amazon for $30 with shipping.
acgcoug is offline
post #114 of 252 Old 02-28-2013, 09:37 PM Thread Starter
acgcoug
1979 CJ5
Quick update: Finished up the other pillar. This side was in better shape.
Sandblasted, phosphoric acid etched and ready for Por 15.
Welded back together.
I also had this section to repair.
acgcoug is offline
post #115 of 252 Old 03-01-2013, 10:45 AM
Renegade82
1982 CJ7
Seems like those spots are the most common place for rot, besides the floors. What's your plan then for the bare metal once all the places have been repaired? POR?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #116 of 252 Old 03-01-2013, 07:49 PM Thread Starter
acgcoug
1979 CJ5
Pretty sure I will coat the inside of the tub with Por 15 and Raptor. For the underneath, Por 15 and Por Chassis Coat Black (frame too). The outside will most likely get epoxy primer and whatever top coat I decide upon.
I do plan on taking everything down to bare metal via sanding and sand blasting to obtain a good tooth for paint.
acgcoug is offline
post #117 of 252 Old 03-04-2013, 11:36 PM Thread Starter
acgcoug
1979 CJ5
Spent the weekend pulling the engine, transmission/transfer case, drivelines, exhaust, and other odds and ends off the chassis.
Before completely stripping down to the frame, I wanted to temporarily set the tub on the frame to check the alignment of the numerous tub body mounts that I repaired, and for any other potential problems with the tub's fitment back on the frame. So far everything lines up very well.
The springs sure perked up without the weight of the engine, tranny and tc on the frame. Kind of looks like I have lift.
Was a fun weekend and a nice break from the monotony of doing metal work. Next I will be working on my fenders and will check their alignment to the tub as well.
acgcoug is offline
post #118 of 252 Old 03-05-2013, 10:27 AM
Renegade82
1982 CJ7
I was just going to reply with those exact words as I read down thru your post. I'm about to push my tub to the side and carry in the frame. I've got about 15 more minutes of welding and I should be done with the tub.... till warmer weather comes. Supposed to snow some more tonight. Hopefully it goes south of us cause the weekends calling for a high of 50.
Any big plans for the engine?
post #119 of 252 Old 03-05-2013, 11:15 AM Thread Starter
acgcoug
1979 CJ5
Yeah, the metal work has been exhausting. The metal work that I am currently doing on my fenders is a bit of a change from messing with the tub so that's good.
The engine will most likely get a complete rebuild. As far as upgrades, not really any major performance upgrades other than a Howell TBI California version. As is, the jeep would not pass emissions. I yanked and boxed up the factory emission junk a few years ago when I lived in Washington State, and replaced the Carter BBD carb with an MC2100 (great upgrade). It was running pretty good, but I'm anxious to see how the TBI system runs/works.
acgcoug is offline
post #120 of 252 Old 03-09-2013, 12:52 PM Thread Starter
acgcoug
1979 CJ5
Time for restoration of my fenders. Passenger side first.
Plan: Fix dings and dents with a hammer and dolly set and various punches hand tools. Replace both inner and outer rotted out panels, coat inner layers with Por15 and weld together.
Spot welds cut out with spot weld cutter.
Picked up a sheet of 20 Gauge steel from my local steel supplier.
Used the existing inner panel to form the shape/contour.
Plug weld the brace and threaded plate back on.
Sandblasted all inner panel layers and coated with Por15.
Worked this dent out.
This one too.
Fits perfect! Forget poorly, foreign made aftermarket fenders. I would rather get frustrated with the effort in restoring original AMC steel than fight that junk to look and fit properly.
On to the driver's side fender....
acgcoug is offline
Coiz 1979 CJ7 Frame Off Resto; picture crazy Coiz Jeep CJ Forum 1945 04-12-2017 05:57 PM
Adam's 82 CJ7 Refurbish Thread Goobs Jeep CJ Forum 15 10-29-2010 08:33 PM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 12:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 08:30 PM
