Adam's 1979 CJ5 Frame-up - Page 4 - JeepForum.com
 2Likes
post #46 of 252 Old 05-27-2012, 04:19 AM Thread Starter
acgcoug
1979 CJ5
Coca Cola will remove rust as well. Phosphoric acid happens to be one of the main ingredients.
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #47 of 252 Old 05-27-2012, 07:06 PM
Skerr
Adam, I'm sorry. I'm not trying to dog on you on the acid. I think you're doing a great job on the build... keep up the good work.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #48 of 252 Old 05-30-2012, 07:39 PM Thread Starter
acgcoug
1979 CJ5
No worries at all Scott, neither myself or my precious acid are offended. Safety first!!!
BTW, gotta love Craigslist. Scored a never been used, 1000 lb HF engine stand for only $25! They retail For $59.99 + tax
At some point I will be getting a hoist to remove the engine from my frame.
acgcoug is offline
post #49 of 252 Old 05-31-2012, 02:09 PM Thread Starter
acgcoug
1979 CJ5
Progress pics:
This little spot was the result of rust developing between a seam on the underside of the tub. Most of the rust was hidden underneath.
Cut out both layers of sheet metal:
Backside:
My makeshift press to form the ribbing.
Finished:
Nasty dent on the rear of the tub where the previous owner backed into a trailer hitch.
All worked out with the hammer and dolly set. The pic looks like the area is still dented a bit, but it is in fact perfectly flat.
acgcoug is offline
post #50 of 252 Old 05-31-2012, 10:01 PM
Coiz
1979 CJ7
Awesome idea with using the punch as a die to form the webbing. I wish I would have done that to a couple small areas of my floor patches.
I don't think I have posted in your thread before but I have been following along. You've been making some great progress. All that metal work can get daunting. Great job.
Mike
Coiz is offline
post #51 of 252 Old 05-31-2012, 10:06 PM
Skerr
I agree with Mike... very cool that you figured out to make the rib. I'll keep that in mind when I start my build.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #52 of 252 Old 05-31-2012, 11:35 PM
2girlsAndaGuy
1979 CJ5
I love visiting this thread, your always full of neat and creative little ideas to help you on your build.
David
2girlsAndaGuy is offline
post #53 of 252 Old 06-01-2012, 01:22 AM Thread Starter
acgcoug
1979 CJ5
Thanks Mike! I agree on the daunting part of the metal work. I feel like I've made a ton of progress with it, yet there is still so much more to do. I just have to keep plugging away.
Appreciate it guys. I've enjoyed all your builds too.
acgcoug is offline
post #54 of 252 Old 06-07-2012, 12:22 AM Thread Starter
acgcoug
1979 CJ5
Fun pics of the kiddos!!!
These pics are a few weeks old, but these are my two little helpers. My 2 year old son and 4 year old daughter.
acgcoug is offline
post #55 of 252 Old 06-07-2012, 07:08 AM
Skerr
Great Pics and Great Kids!! They grow so fast...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #56 of 252 Old 06-07-2012, 07:34 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Adam,
Strong work, so far, and a great thread.
I, too, am a huge fan of Prep & Etch. The stuff is amazing, and cheap too. I used a similar product called Rust Mort before I discovered P&E. The Rust Mort was equally effective, but it was about 3 times more expensive than P&E.
Matt
Matt1981CJ7 is online now
post #57 of 252 Old 06-07-2012, 09:37 AM Thread Starter
acgcoug
1979 CJ5
Originally Posted by Matt1981CJ7 View Post
Adam,
Matt
Thanks Matt!
By the way, what kind of primer and top coat do you use over phosphoric acid prepped metal. In addition, what primer over the black iron phosphate (converted rust)?
acgcoug is offline
post #58 of 252 Old 06-12-2012, 09:38 PM
keith460
Jeep. There's Only One
keith460's Avatar
Nice metal work going here to save the tub and having it look original with all the little details you are doing. Making ribs and forming metal by any means necessary with common shop tools is always an A+ in my eyes. People with ingenuity like you are always going to come out on top no matter what comes up and it gets easier and better looking as it comes along.
Nice work!
1984 CJ-7 Renegade
keith460 is offline
post #59 of 252 Old 06-19-2012, 12:05 AM Thread Starter
acgcoug
1979 CJ5
Nice work!
Very classy post Keith! Thank you very much
acgcoug is offline
post #60 of 252 Old 06-19-2012, 02:07 AM Thread Starter
acgcoug
1979 CJ5
Update:
I've been working on fixing some of the rusted areas on the back end of the jeep. Valence repair, rear body mount repair, sheet metal repair near gas filler, and body mount cage repair.
The ugly shots:
Valence:
Valence pulled and in bad shape:
Rear driver's side body mount area in bad shape:
The Good!!!
Cleaned up valence with one repair piece ready to be welded on soon:
Bad section cut out:
Making the new piece. The dotted lines are the folds/bends. Don't mind the surface rust, it was removed:
Tacked on:
New body mount plate made:
Making a new body nut/bolt cage:
Welded up:
I'm about ready to move on to the other side, and once that side is finished I will coat the inside of the rear body mount channel, re-install the repaired valence, and then move on to the next challenge. This area has been very time consuming and a major PITA! Making progress though.
acgcoug is offline
Coiz 1979 CJ7 Frame Off Resto; picture crazy Coiz Jeep CJ Forum 1946 07-19-2017 05:26 PM
Adam's 82 CJ7 Refurbish Thread Goobs Jeep CJ Forum 15 10-29-2010 09:33 PM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 09:44 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 01:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 09:30 PM
