I am installing a NV4500 and it currently sits at 2.5*, sloped to the rear.
It is sitting on the skidplate (not mounted yet).
What I am trying to figure out is whether it can stay at 2.5*, go maybe to 0* or does it need to be nearer the "stock" engine angle of 5* (measured of a stock CJ that a buddy of mine has).
I can mount the NV now, but that will push the trans a little higher (clearing with a 1.25" body lift I hope) and that may push the engine more toward 0*.
I will be running an electric fan, so that isn't an issue.
I'll have to work out driveshaft angles as well. Need to give Tom Woods a call.
ΜΟΛΩΝ ΛΑΒΕ!
Do your duty in all things. You cannot do more, you should never wish to do less.
Robert E. Lee
Groups
Originally Posted by DiabloYJ
It's a Jeep thing, I don't even understand it sometimes.
1981 CJ-7, AMC 360 bored .30 over, Edelbrock Intake, Edelbrock Cam, Edelbrock Double Roller Timing Chain, Holly 650 truck avenger carb, Flowcooler water pump. '97 Dodge 4wd Std NV4500. D300 Twin Sticked. Corbeau Seats, Custom Dash with Autometer guages, Electronic Speedo, all stainless hardware, Outlaw II Wheels, BFG AT 33" Tires, Flex-A-Lite Dual Electric Fan, AGR steering box, Borgeson steering shaft, ididit tilt column, Mean Green Starter, Tuffy console, poly gas tank, handmade rear bumper. (needs a radio and speakers)
2000 XJ - HO 4.0L, Goodyear Wrangler Duratracs. PSC gearbox. IRO Double Shear Trackbar. New headliner. IRO Hack & Tap SYE. IRO adjustable UCA & LCA. Future mods: RE 4.5" lift, OTK steering. Sway bar disconnects.
