Quantcast Accel DFI Thruster for 4.0L questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Accel DFI Thruster for 4.0L questions
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-14-2009, 05:12 PM   #1
UncleWally
I finally found a system that will work on a 6 cyl other than the Mopar setup. Has anyone used this yet on a 4.2L build with a 4.0L head?
Let me know as I'll have several questions for you.
Thanks in advance,
Waldo
I'm beggining to understand the true meaning of 'Just Empty Every Pocket'!
UncleWally is offline   Reply With Quote
Old 05-16-2009, 08:36 AM   #2
UncleWally
Spoke with Golen Engine Services yesterday about their 4.6L Stroker. The guy I spoke with said this DFI setup was the way to go if you don't already have the EFI system from Mopar.
So a bump to the top....
Anyone have experience with it?
Waldo
Old 05-16-2009, 10:24 AM   #3
gmakra
Not with the Accel but with Golen I would seriously check and see if the cam the are supplying you with will work with EFI.
I had a Golen and it lasted 5000 miles then I rebuilt it the proper way. You will hear the same about Titan and any other prebuilt stroker.
Check out this site if you are contemplating a stroker.
http://www.jeepstrokers.com/forum/
gmakra is offline   Reply With Quote
Old 05-16-2009, 10:51 AM   #4
skydog61
1978 CJ5
I used to work at a shop that is an authorized ACCEL installation center. They have a good product, generally it installs easily and works good.
skydog61 is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
