Absolute most minimal way to mount a winch? - Page 2 - JeepForum.com
post #16 of 33 Old 10-11-2011, 07:09 AM
mopar346
Now what's a "rock climber haul system 2-1 or 3-1?" Never heard of such a thing...
__________________________________________________ ____________________________________________
It's a pulley system designe
d to multiple torque/pulling power I believe.
Wellmax - how thick is your plate, I am going to build my own with flat plate across the frame and then a v shaped flat bar from the center to tie into the frame about foot or so back. Used 1/2 inch on the last one I built for an S-10 but that may be overkill on a CJ. I plan to run reese receivers front and rear for multiple uses out of one winch.
Careful your character's showing
mopar346 is offline
post #17 of 33 Old 10-11-2011, 07:51 AM
alljagged24
Interesting,I'm doing my winch research,prob gonna be an 8000 lb also.......I'm glad you said the ramsey bolts to the bottom, that won't work.....I'm prob going to have bersk custom build mine bc I cut the ends of the factory bumper off and welded them to the sides of the frame and have semi truck. Tow hooks bolted and welded to the frame, prob gonna make it interesting putting a winch on
Not trying to hijack just wanted to receive all the replies on this post
fresh 258 .030 over comp cam ,clifford intake and header , holley 390 soa with procomp 2.5 in lift springs,2.5 in lift perches, d30 with detroit true trac, ford 8.8 performance limited slip 4.10 gears , 37 in iroks, custom bumpers and recovery points, super lined inside , no rust , fresh flat black paint, tested at trucksgonewild!!!
alljagged24 is offline
post #18 of 33 Old 10-11-2011, 08:41 AM
SKT
1981 CJ7
Originally Posted by aBoyAndHisCJ View Post
How can I mount a winch to my CJ-7...
Can you post up some pics of your '7?
SKT is offline
post #19 of 33 Old 10-11-2011, 12:05 PM
wellmax
do not know for sure, 3/8 thick i guess, but has been said before "do not go cheap" a lot of pressure on the plate and frame connectors.
another thing i will not do "hook the rear hitch to a tree, to keep winch from dragging the jeep when making a pull, if the jeep is being pulled along the ground with the brakes locking all the wheels, then that is about all the little jeep frame needs. you are about to tear something up on your jeep.
just my opinion.
most everyone wants a winch on their jeep, but not everyone needs one, if you know what i mean!!!!!!
have a good day!
wellmax is offline
post #20 of 33 Old 10-11-2011, 12:32 PM
1980tallcj7
1980 CJ7
1/4" steel plate
http://www.summitracing.com/parts/RWC-295137/
1980 CJ7,
1980tallcj7 is offline
post #21 of 33 Old 10-11-2011, 01:13 PM
mopar346
Thanks for the info, one of the reasons to have a "portable" winch is so that when needed it can be mounted to other vehicles, many people have reese receivers. A CJ is not a pull truck it is for carrying its own weight and nothing more. When a pull truck is needed enlist a fullsize long wheel base big block monster, but don't throw it in a hole cause you aint never getting it out if it don't come out on its own. I also can move the winch to a trailer, quick connects on everything you intend to use it for and a GOOD set of jumper cables with quick connects for those surprises, no reason to buy 3 or 4 winches. Just my thoughts, right wrong or otherwise, but again thanks for the info.
mopar346 is offline
post #22 of 33 Old 10-11-2011, 01:28 PM
swatson454
1983 CJ7
I've mounted one with little less than two shots of tequila and a few kind words
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #23 of 33 Old 10-11-2011, 06:30 PM
mopar346
That's just wrong, funny but wrong!
mopar346 is offline
post #24 of 33 Old 10-11-2011, 09:21 PM Thread Starter
aBoyAndHisCJ
1978 CJ7
wellmax is dead on— anchoring your Jeep at one end while winching from the other end will pull your Jeep apart. If you really find it necessary to do more than hit the brakes, you're supposed to anchor from the same end of the frame you're winching from.
@SKT— I sure will post some pics after I get a new coat of paint this week. Unfortunately, I set the Jeep on fire a couple of nights ago. Anything in particular you were interested in seeing? The M8000 isn't quite mounted yet...
The problem with Jeeps is that everyone fancies himself some kind of Adventurer after he buys one. As if courage, or ruggedness, can be had for a mere $27,745 MSRP
aBoyAndHisCJ is offline
post #25 of 33 Old 10-11-2011, 09:38 PM
SKT
1981 CJ7
@SKTó I sure will post some pics after I get a new coat of paint this week. Unfortunately, I set the Jeep on fire a couple of nights ago. Anything in particular you were interested in seeing? The M8000 isn't quite mounted yet...
Nothing in particular, just curious what the Jeep in discussion looks like.
I didn't see any pics when I looked through your previous posts.
SKT is offline
post #26 of 33 Old 10-11-2011, 09:56 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Run a decent winch plate.. they weigh about 20lbs or so and are worth the safety margin. Swap to synthetic line and only fill the Jeep to 3/4 full in the gas tank and you'll come out ahead on weight..
BESRK is offline
post #27 of 33 Old 03-31-2015, 06:31 PM
Agent_Orange
I have a Ramsey 8000# on my 85 and the PO used a 1/4" plate mounted on top of frame rails and stock bumper. I think like 8, 1/2" grade 8's and some tightly packed snow hold it in place.
Some guys think if they have a cool Rig they are better than other guys... and those guys are right!
Agent_Orange is offline
post #28 of 33 Old 04-01-2015, 07:27 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
After 4 years, I think the OP probably figured out how to mount his winch.
Matt
Matt1981CJ7 is offline
post #29 of 33 Old 04-01-2015, 03:16 PM
duffer
1955 CJ3B
I went the minimal route on my 3B. Material wise, anything more than 1/4" plate in a properly engineered mounting is pure overkill and you are just packing around useless extra weight. This is all boxed with 1/4".
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
post #30 of 33 Old 04-02-2015, 04:21 AM
2001WJv8
2015 WK
Matt
haha ... or he's stuck in the woods still
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
winch install , winch plate
ABSOLUTE SMALLEST LIFT FOR 33's grady4x4 Jeep CJ Forum 19 05-01-2013 03:47 PM
Winch Mount On CJ-7 davbytrace Jeep CJ Forum 1 09-17-2011 07:36 AM
Which winch mount?? scooter Jeep CJ Forum 1 11-14-2009 11:49 AM
Absolute easiest/quickest way to put Dana 44s on a CJ7? nathanm40a1 Jeep CJ Forum 3 08-22-2009 07:36 AM
How did you mount your winch 390fastback Jeep CJ Forum 1 10-17-2003 11:36 AM
