Absolute easiest/quickest way to put Dana 44s on a CJ7? - JeepForum.com
post #1 of 4 Old 08-22-2009, 03:59 AM Thread Starter
nathanm40a1
I am somwhat limited in my abilities working on my Jeep, I was wondering what the easiest quickes way to put dana44 axles on my CJ would be? I have an 84 so its already a wide trac, I wouldnt mind a few inches wider on the axles but would like to avoid it if possible. I do not know much about fabrication and wanted to know if there were donor vehicles that would allow a direct swap and if not what the quickest route to getting D44s on my jeep would be with no more than 2 to 4 inches wider axles? Sorry if this has been covered but I have a pretty specific idea of what I want and thought it would be easier to just post a thread.
nathanm40a1 is offline
post #2 of 4 Old 08-22-2009, 07:03 AM
garbageman
1979 CJ7
Find someone who has already done the swap and is upgrading again. Then buy theirs. Direct bolt in.
For the most part, a little work will be required - grab some waggy axles and change the perches. Then outboard your springs of the frame. Can be done in a weekend.
1979 CJ7 - Propane powered 258/TH400/Q-trac- 2015 Project
Sold:
1974 CJ5, 1980 Wagoner, 1976 CJ7
garbageman is offline
post #3 of 4 Old 08-22-2009, 07:38 AM
Hank86
Hank86's Avatar
Some of the 86 CJ7's came with a Dana 44. Its a direct bolt in. The only thing different is the u bolt backing plate are alittle bigger and you will need a little larger U Bolts.
86' CJ7 - 258 - Weber 32/36 Carb, T-5, 300 transfer case, Dana 44 rear w/ 3.31 Gears, 33" ProComp M/T on 15x10, with a 2" Body Lift, 1 1/4" shackle lift.
Hank86 is offline
post #4 of 4 Old 08-22-2009, 08:36 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Buy a 1986 CJ-7 WT D44 rear and a front housing that has already been built (with the diff not in the way of the passenger leaf), like this one:
Cj wide track 44 front - Great Lakes 4x4. The largest offroad forum in the Midwest
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
ABSOLUTE SMALLEST LIFT FOR 33's grady4x4 Jeep CJ Forum 19 05-01-2013 04:47 PM
World's Quickest Jeep TexasCJ7 Jeep CJ Forum 23 09-16-2009 08:19 AM
Easiest way to remove the tub? wwhitby Jeep CJ Forum 9 04-21-2006 10:47 PM
Best & Easiest Axle Swap for CJ 77deluxe Jeep CJ Forum 7 12-03-2005 09:34 AM
Easiest way to lift jeepin'bo Jeep CJ Forum 2 03-01-2005 03:11 PM
