About to Nutter - What has the PO done?? - JeepForum.com
post #1 of 5 Old 12-09-2009, 06:53 PM Thread Starter
bombdude
Ok. I printed luckyheesehead's thread on how to nutter from Feb'08. Been studyin' up & was ready to tackle it.
First thing I found was that the stepper motor was already unplugged, so I'm thinkin' that it's already been nuttered.
Pulled out the wiring & the wires have not been bypassed. They are stock.
OK, so at this point I'm continuing to read the thread & see that the distributor vacuum hose is already connected to the left side vacuum port. It isn't spliced as instructed, so I don't know where the original line would have gone. There are a couple plugged lines from the back of the carb.
The line from the original vacuum port where the dist line was supposed to be hooked up goes to the canister on the driver's fender (front position)
Interestingly, the second line on the canister just hangs & isn't plugged. Don't know where it goes.
Couple things I've played with. I can plug the stepper back up - no difference.
I also can't get the stepper pin to move by adjusting the idle mixture screws, plugged or not. As a matter of fact, closing the screws all the way doesn't affect the running of the Jeep. It actually runs "fair". Better than when I first got it. Some copius application of carb spray has gotten it idling ok, but it still "coughs" occasionally.
Overall, I still believe that I can do the nutter w/o a problem. Just not sure about the vac lines & pin movement.
Any help would be appreciated.
bombdude is offline
post #2 of 5 Old 12-10-2009, 07:01 AM
Mike Romain
A $20.00 carb kit will sure help make it purr.
The stepper seems seized. You can remove it and set the pins up for good running with their shoulder about 1/8" from the back wall:
You can do the wiring with no issues, then the timing and carb mix.
Here is where the vacuum lines go: Vacuum Hose Hook Ups - JeepForum.com
The canister purge line T fits to the PCV line behind the carb. The canister vacuum signal has to go through the CTO valve.
Mike
Mike Romain is offline
post #3 of 5 Old 12-11-2009, 07:30 PM Thread Starter
bombdude
Thanks Mike.
And, well, I took your advice & picked up a kit for the BBD. Haven't found a 1.08 2100 yet. Got it torn apart last nite, Good Lord that's a lot of parts. Got it soakin now.
Next question is the stepper. I can't get the needles to move at all. The center shaft won't move.
Does the metal shaft move, or is it the orange plastic housing the the shaft goes into. And can I lube it in some way to get it to move??
bombdude is offline
post #4 of 5 Old 12-13-2009, 06:22 AM
Mike Romain
I would soak it in penetrating oil. If I remember right, the center shaft moves. It moves in steps so rocking it may loosen it up. I think I have had most luck making the center move out first, then it goes back in.
When the pins are set right, the fiber board the pins fit into will be 'just' inset into the stepper bore enough to capture the pins so they can't fall out.
Mike
post #5 of 5 Old 01-18-2010, 11:14 AM Thread Starter
bombdude
I know it's been a month, but I wanted to update.
The kit really helped as Mike stated it would. Still had an occasional cough, but definitely better. So i went with this, & finally completed the nutter last nite. As stated, the dist vacuum hose was already hooked up to the ported vent, so I didn't change anything with the hoses.
When I checked the timing, it was advanced off the chart!! At idle it was beyond the marks. Slowed it down to 8 deg, & now it really purrs. I don't have a tach, so I don't know my RPM's, but now it has a nice slow idle. I took it for a short spin last nite, & it seems to run great. I'll be checking mileage (last tankful I got 10mpg, ugh!!) & performance changes in the next few days.
Thanks, Mike for your responses. Your willingness to share your knowledge is greatly appreciated.
bombdude is offline
My Nutter Experience. Praise Nutter (and Luckycheesehead)! Sixcarbs Jeep CJ Forum 3 04-18-2009 03:52 PM
Anyone want to help me nutter? In N. Fla... jlr69s Jeep CJ Forum 9 04-29-2008 08:41 PM
Nutter mod Truck633 Jeep CJ Forum 6 03-14-2007 12:22 PM
The Nutter headgasket Jeep CJ Forum 0 03-06-2006 08:14 AM
to nutter or not to nutter? wm69 Jeep CJ Forum 3 07-20-2004 07:05 AM
