9in rearend 50$ - JeepForum.com
post #1 of 7 Old 05-13-2003, 01:28 PM Thread Starter
soler
9in rearend 50$
I have a 1958 willys CJ5 Will this work with my Dana 18 t- case? Is this a good deal? It does not come with gears. Will this be able to handle some serious power? They want 50 dollars
soler is offline
post #2 of 7 Old 05-13-2003, 06:03 PM
Milkman_Dan
Milkman_Dan's Avatar
so, basicly your getting a 9in case for 50 bucks? If it had gears it would be a good deal, but your going to spend alot more for the 3rd member. If it had it all it would handle some serious power. The next problem would be getting it to fit.
I hate you milkman dan....
80 cj5
no body, but it's got 34's!
amc 20 w/one piece axle's
304...
Milkman_Dan is offline
post #3 of 7 Old 05-13-2003, 10:32 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
The T-case does not matter, as you will likely need a new rear driveshaft (more $), and you just need the correct yoke at each end. Also, 9" 3rd members are expensive. Lastly, on a nice short CJ-5, you may find that the low pinon on a 9" will create and unacceptable driveshaft angle., but since it will need new spring perches (more $), you could rotate it up a bit.
Seems like it's not worth the effort, and unless you are going to be running big tire and lots of HP, it may not be worth it.
But, what the hell, maybe it will work.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #4 of 7 Old 05-14-2003, 04:21 PM
rustyCJ
a centered 9in behind an offset rear output dana18 in a CJ5? that would be an interesting rear driveshaft.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #5 of 7 Old 05-14-2003, 06:17 PM
CSP
Yes the tcase will matter. His Dana 18 tcase has the rear output offset to the passenger side. The Ford 9" is most likely a centered input. On a short wheelbase CJ5 that's just too much angle for any driveshaft to handle.
Other than that immediate obstacle, not all 9"s are created equal. Many are only 28 spline and have very small bearings.
CSP is offline
post #6 of 7 Old 05-15-2003, 07:25 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
OK!, mia culpa, forgot about the 18 and the offset
CJeep is offline
post #7 of 7 Old 05-15-2003, 10:08 PM
maestro
i got a d44 offset rear out of a 75 wagoneer that might work out for ya, its in peices though and im in winchester MA
1985 jeep cj7,258 with mopar MPI, borla header, custom flowmaster exhaust, 1.5 inch body lift, 3.5 inche suspension lift 31inch tires,mean green alternator
maestro is offline
Identifying rearend rokcrawler3203 Jeep CJ Forum 12 12-26-2007 11:15 AM
Rearend help please. cjheven Jeep CJ Forum 12 09-15-2006 04:49 AM
Rearend is gone!! plmoss21 Jeep CJ Forum 6 03-01-2006 05:39 PM
AMC Model 20 Rearend Raiderfanatic Jeep CJ Forum 9 05-25-2005 05:47 AM
price for a rearend contender54 Jeep CJ Forum 8 02-09-2004 12:22 PM
