99' vortec 350 CJ7, wiring starter & 2 solenoids?? - JeepForum.com
post #1 of 4 Old 02-07-2010, 06:02 PM Thread Starter
skhcj7
Ok, I am installing a 99' vortec 5.7 350 from a suburban into my 84' Jeep CJ7. I got my engine harness made by a company and only wires to hook up are the purple starter wire, ignition hot, battery hot, ground, and fuel pump wire. Of course the rest of the sensor wires just plug in. My question is with the starter and solenoid? Since the 350 has the solenoid on top of the starter and my harness hooks to the purple wire on starter, can I just eliminate my jeep solenoid that was on the fenderwell? The only other cable on the chevy starter of course goes straight to the positive side of the battery. No need for two solenoids is there?
I tried leaving the jeep fenderwell solenoid unhooked but then my ignition wires in the factory jeep harness would not work. Can someone give me details and/or a diagram of how they did theirs?
thanks,
Shayne
skhcj7 is offline
post #2 of 4 Old 02-07-2010, 07:37 PM
wrongway92407
wrongway92407's Avatar
Shayne, I believe that I hooked the Blue wire from the jeep solenoid to the purple starter wire, it should only have power in start. I used the red 10 gauge with the white tracer for the hot ignition. I found a power strip in the pic a part and ran a 6 gauge to it and I then used that for my battery and used a couple of the other terminals for ACC.s. I clipped those 2 wires about 6" out of the fire wall connector and hooked up the chevy. After I got every thing working I removed the fire wall connector and removed the rest of the wires. I didn't cut any except for the 2, someone will need a harness some day. I won't pickup my jeep from my son until tomorrow evening and will double check the wires. By the way who did you have make your harness and what kind of trans are you using?
Dave
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #3 of 4 Old 02-08-2010, 05:24 AM
Mike Romain
Why reinvent the wheel? Even the CJ's with the GM engines have the fender solenoid, it works and is easier to hook up than having all the wires down below where a tree branch can easily take them out.
Mike
Mike Romain is offline
post #4 of 4 Old 02-08-2010, 09:03 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I've heard where people will actually use a Ford setup on their Chevy since the one on the starter has a tendency to get cooked, being under the headers of HP engines...
Rick
Cutlass327 is offline
How do the vacuum solenoids work - wiring bleoh Jeep CJ Forum 15 07-24-2016 03:52 PM
Need some Starter / Starter wiring help please! SparkyCJ7 Jeep CJ Forum 14 09-09-2009 06:27 AM
Starter wiring question lacpa Jeep CJ Forum 2 06-07-2008 05:21 PM
starter solenoid wiring help T-$$ Jeep CJ Forum 4 09-02-2005 11:07 AM
Need help with Starter Solenoid wiring Marc CJ7 Jeep CJ Forum 17 04-19-2004 05:22 PM
