9.5" tire on 12.5" wheel? - JeepForum.com
post #1 of 13 Old 05-05-2013, 07:33 AM Thread Starter
CJKevin1978
It it would even work, how strangely shaped would the tire be?
My problem is that my Jeep has nearly new tires which I like. But they are pretty narrow and mounted on white wheels which I don't care for. I found a set of aluminum wheels near me on CL but they are wide.
I would prefer to use these tires as I assume that used tires are hard to get any $$ for.
Secondary question: Do all CJs come with 5 X 5.5 hubs?
CJKevin1978 is offline
post #2 of 13 Old 05-05-2013, 09:18 AM
jeepwhore
Personally, I wouldn't attempt what you're suggesting and I'd be surprised if you could find a tire shop that would even mount that combination. And yes, all CJ's had the 5x5.5 BP.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 13 Old 05-05-2013, 09:21 AM Thread Starter
CJKevin1978
That's kinda what I was thinking. Seems like too much difference between the tread with and bead width. Appearance-wise, I'd prefer a wheel that is a little too narrow over too wide.
post #4 of 13 Old 05-05-2013, 09:22 AM
roadhog304
1973 CJ5
Mounting that narrow of a tire on that wide of a wheel is just asking for bad things to happen. either find a different set of wheels or get new tires for them.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #5 of 13 Old 05-05-2013, 02:49 PM
streetpro
1978 CJ7
Working in a shop long ago, lots of low riders wanted skinny whitewalls stretched on to wide wheels. If thats the look you're shootin' for then go for it. If not, and hydraulics aren't in your future, then you will need a REALLY wide tire to fit that 12.5 wheel. I have 33x12.5R15 on 15x10 and methinks 15x9 would be better.
streetpro is offline
post #6 of 13 Old 05-05-2013, 10:05 PM
RDH
Quit getting antsy and wait for another set of wheels to come along.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #7 of 13 Old 05-15-2013, 05:46 PM Thread Starter
CJKevin1978
It looks like I will be getting a set of mid-70s slotted jeep wheels and will probably put my current tires on them. Then when the time comes, I will look into whether the tire size that I like will fit these wheels. I am not going really big so my guess is that 11.5s will be no problem on these. I think they are 8s.
post #8 of 13 Old 05-18-2013, 02:42 PM Thread Starter
CJKevin1978
https://dl.dropboxusercontent.com/u/...144730_522.jpg
Whatcha think? They need some polishing but when you consider that they've been neglected for the past 15 yrs, they're in pretty good shape. I think they are original Jeep wheels but I could not find any markings inside them. They do have the valve-stem inside one of the slots.
I may even run those tires. They are worn (maybe 25% left) but one inch bigger and one inch wider.
post #9 of 13 Old 05-19-2013, 07:42 PM
RDH
I like em.
RDH is offline
post #10 of 13 Old 05-19-2013, 07:45 PM
80cj
80cj's Avatar
1980 CJ5
9.5" tires will go well on 8" rims. Wait for a set of those to come along.
80cj is offline
post #11 of 13 Old 05-20-2013, 09:06 AM
DougE
1983 CJ7
The sidewalls would be extremely vulnerable with that set up.
1983 CJ7, 258I6, T4, Dana 300, 2" Lift, 31x10.5x15 DuraTrac
DougE is offline
post #12 of 13 Old 05-20-2013, 03:17 PM
13riverking
1981 CJ7
I have 12 inch rims running 14.5 inch wide tires. Just bought the tires and would never think of a narrower tire. Almost bought new wheels to save money on tires down the road. Personally I would never by another 12 inch wheel. Tires are to expensive, hard to balance, and wander on the road at that size.
13riverking is offline
post #13 of 13 Old 05-20-2013, 03:31 PM
80cj
80cj's Avatar
1980 CJ5
Stretching a 9.5" tire on a 12" rims , you'd really be stretching the tire out and the OD of the tire would also be affected. Tire manufacturers normally have a chart with recommended rim widths on their web sites.
80cj is offline
