'88 manifolds on a '76? - JeepForum.com
post #1 of 8 Old 09-11-2013, 12:54 PM Thread Starter
Grumpy_one
1976 CJ5
I want to convert my single draft hole into a MC 2100 project. Would a set of '88 intake/exhaust manifolds do the trick for me? Smog?
Grumpy_one is offline
post #2 of 8 Old 09-11-2013, 01:17 PM
CSP
They can work. You'll need shorter bolts and if you have power steering one of our pump brackets will need to be clearanced.
I have no idea what your smog requirements are so I can't comment on that.
CSP is offline
post #3 of 8 Old 09-11-2013, 02:45 PM Thread Starter
Grumpy_one
1976 CJ5
Do tell
post #4 of 8 Old 09-11-2013, 04:42 PM
CSP
The exhaust manifold juts out (for lack of a better description) further away from the head than the stock one does. You have to cut away part of one bracket for this.
CSP is offline
post #5 of 8 Old 09-12-2013, 01:24 PM Thread Starter
Grumpy_one
1976 CJ5
I thought you had a bracket for sale when you said "our" and "clearanced".
post #6 of 8 Old 09-12-2013, 01:29 PM
CSP
That should have said your, not our. I didn't even notice that.
CSP is offline
post #7 of 8 Old 09-12-2013, 02:36 PM Thread Starter
Grumpy_one
1976 CJ5
No problem CSP. Another question, my 76 exhaust manifold is a flush fit (no gasket), will the 88 be the same?
post #8 of 8 Old 09-12-2013, 03:28 PM
CSP
They both can be mounted with a gasket actually. I would recommend a gasket as they can (and usually do) warp some.
CSP is offline
