'86 D44 wheel studs? - JeepForum.com
post #1 of 5 Old 04-17-2012, 05:03 PM Thread Starter
tdkask
I have a stock D44 out of an '86 in my '80 CJ7, and need to replace the wheel studs. I went to the local parts stores (Autozone, Advance, and Napa) and they all point to the same piece for that application, with no accounting for the AMC20 v/s D44 differences. I tried them just in case and got no luck... just slightly too big.
What would be the best application for wheel studs to work in this? Do I have any options other than just taking a dial caliper and catalog to NAPA?
Thanks.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #2 of 5 Old 04-17-2012, 06:03 PM
only in a jeep cj
That may be because the two do share the same brake/drum parts......But I've never compared the wheel studs. I would press an old one out and carry it in to the auto parts place.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 5 Old 04-17-2012, 06:09 PM
mrgimble
2015 JK Wrangler
My AMC 20 and D44 were the same. When I swapped in a '74 D44 I used my '81 AMC 20 studs.
mrgimble is offline
post #4 of 5 Old 04-17-2012, 06:11 PM Thread Starter
tdkask
Originally Posted by mrgimble View Post
AMC 20 and the 44 are the same. When I swapped in a '74 D44 I used my '81 AMC 20 studs.
Mine are definitely a little larger... calipers don't lie. I wonder if the '74 and '86 D44's are the same?
Anyone have any info on what shafts they used to make the ones for that axle, as it is a unique application for just part of that year, right?
tdkask is offline
post #5 of 5 Old 04-17-2012, 06:30 PM Thread Starter
tdkask
I think this clears it up...
http://www.quadratec.com/products/52428_01.htm
Rear Axle Wheel Stud
For 76-86 Jeep® CJ Series with AMC Model 20 Rear Axle & 86 CJ-7 with Dana 44 Rear Axle
Quadratec Part No: 52428.01
Manufacturer Part No: J5355719
tdkask is offline
Wheel studs GADJIT98 Jeep CJ Forum 3 10-20-2013 07:57 PM
tricks to pop wheel studs in Wrangler11 Jeep CJ Forum 18 02-19-2011 02:16 PM
Need wheel studs for 63 CJ5 ??? rocks4x4 Jeep CJ Forum 0 07-29-2010 11:47 PM
wheel studs jamesa Jeep CJ Forum 4 06-03-2006 12:00 PM
???wheel studs??? scottahicks Jeep CJ Forum 0 02-07-2003 12:51 AM
