'86 CJ7 won't start. - JeepForum.com
post #1 of 11 Old 08-24-2013, 03:17 PM Thread Starter
0hcanada
Stopped at the gas station and Jeep wouldn't re-start. Upon trying barely would register a reading on the Voltmeter, then the odd time would; intermittent; but only about a 10. Would read better on ACC (Accessory) a 12. A couple of days ago at the carwash when I turned the key to the ON position, the needle on the Oil Gauge moved up, down, up, down, ...... and the Voltage meter registered nothing then all of a sudden moved up and the Jeep finally started preceded by a slight hesitation on starting. Then today, nothing.
Tried boosting, but all I got was a clicking. Tried a few times, even tapped starter and solenoid. No luck.
Pulled battery and had it 'Load Tested'. Came back GOOD (Voltage: 12.52V; Measured 508 CCA; Rated 630 CCA; Temperature 23 degrees), but low on charge so added some distilled water (one cell fairly low), and am now trickle charging overnight.
Have since read a few old threads here and sounds like problem could be anything from a battery issue (above?), cable from battery to solenoid, or dirty grounds.
Be curious to hear some thoughts/suggestions.
Is there a short cut to start the Jeep where I could get it home/moved; if so how?
0hcanada is offline
post #2 of 11 Old 08-24-2013, 04:07 PM
Jeeper44mag
1978 CJ7
Check all connections first. It's very possible that you have an inadequate ground.
Luis
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #3 of 11 Old 08-24-2013, 04:43 PM Thread Starter
0hcanada
battery to solenoid and/or battery to block?
0hcanada is offline
post #4 of 11 Old 08-24-2013, 06:12 PM
shadoow
check em all: battery to solenoid, solenoid to starter, battery to block and both battery connections on the battery terminals. Make sure they are clean and tight.
shadoow is offline
post #5 of 11 Old 08-25-2013, 11:23 AM Thread Starter
0hcanada
thanks boyz. all fixed up and running again. cleaned all my contacts (battery clamps, posts, solenoid, starter and block connections, ....). am all good again.
thanks for all the heads up and advice.
0hcanada is offline
post #6 of 11 Old 08-26-2013, 07:02 AM Thread Starter
0hcanada
actually one last question.
would I be best to convert ALL these connections with white lithium grease?
if not all, which connections? and if not white lithium grease, which kind/type of application?
thanks.
0hcanada is offline
post #7 of 11 Old 08-26-2013, 07:19 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think white lithium grease hardens over time when it's exposed to air. I wouldn't use it.
If anything, buy some conducting lubricant from an electrical supply company.
Matt
Matt1981CJ7 is online now
post #8 of 11 Old 08-26-2013, 10:06 AM Thread Starter
0hcanada
great thanks for the info.
0hcanada is offline
post #9 of 11 Old 08-26-2013, 11:40 AM
shadoow
dielectric grease
shadoow is offline
post #10 of 11 Old 08-26-2013, 01:43 PM
jdarg
Dielectric grease can actually cause issues because it is non-conductive. Something like Caig Deoxit would work much better in this application.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #11 of 11 Old 08-26-2013, 03:58 PM
LumpyGrits
Originally Posted by shadoow View Post
dielectric grease
NO-That can stop contact.
What does the first 3 letters(Die)tell you in it name.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
