86 cj7 intake connections - JeepForum.com
post #1 of 8 Old 03-29-2012, 06:04 PM Thread Starter
warrior1670
What are the connections in this pic? They are all into the manifold. This isn't my jeep just a pic I found but I don't have anything connected to any of these on mine.
warrior1670 is offline
post #2 of 8 Old 03-29-2012, 06:06 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
From front to back:
Heater hose, CTO, CTO, manifold vacuum
LT1CJ7 is offline
post #3 of 8 Old 03-29-2012, 06:53 PM Thread Starter
warrior1670
is the heater hose onto the intake necessary? seems counter intuitive since colder air is denser and produces more power or is this a carb thingy? i'm an EFI guy.
post #4 of 8 Old 03-29-2012, 06:56 PM Thread Starter
warrior1670
so reading other posts (with the search function), the second cto in the pic goes to the carb and such. does the first just get blocked off or can it be left open. The extra's on the second cto need plugged right?
post #5 of 8 Old 03-29-2012, 07:02 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
If you want to stay warm in the Burgh winters
It also helps warm up time.
I wouldn't worry about power loss from the 258.
LT1CJ7 is offline
post #6 of 8 Old 03-29-2012, 10:10 PM
248107
1983 CJ7
this might help you out,plus there's a factory service manual posted in the forum also for 84-86
http://home.sprynet.com/~dale02/home.htm
248107 is offline
post #7 of 8 Old 03-29-2012, 10:46 PM
1986cj
Not that it matters but that intake is pre 83ish. You have no knock sensor port.
1986cj is offline
post #8 of 8 Old 03-30-2012, 06:19 AM Thread Starter
warrior1670
Yes, this is pre 83. the Jeep had a 4 cyclinder that he PO swapped out. 258, T150, D20. The computer is there but not connected to the carb.
fuel tank connections troyer Jeep CJ Forum 2 03-09-2012 03:06 PM
need diagram of amc 360 vacuum connections howelljeep Jeep CJ Forum 2 07-25-2011 10:05 PM
Help with Connections...Keeping my day job TwoFace774 Jeep CJ Forum 3 07-14-2011 11:53 PM
Column connections - help! KelticDog Jeep CJ Forum 3 08-26-2010 11:28 AM
Brake Connections to the prop value Later_THANKS Jeep CJ Forum 5 06-14-2007 06:11 AM
