86 CJ7 Headlights quit - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 86 CJ7 Headlights quit
Savvy Aluminum Gas Tank SkidWIN a set of Mammoth Boulder Wheels at ExtremeTerrain.com!Truck & Jeep Fest 2015 - Edmonton
Unread 04-29-2015, 06:05 AM   #1
RamadiRat
one day all is well, next it's not. Pull the light switch out, and everything is fine except no headlights. The only fuse I see is the three amp fuse for the light switch/reostat itself...
Any other obvious things I need to check before I start real troubleshooting?
RamadiRat is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 06:26 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Give the dimmer switch a kick and see what happens.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 04-29-2015, 06:50 AM   #3
dspec
I 2nd the dimmer switch
dspec is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 07:56 AM   #4
Jsadamson1
Check for voltage at the wires and work your way back. Don't rely on the lights actually shining, made that mistake before. Then I recommend the headlight wire upgrade listed somewhere here on the site. My headlights never worked better or shined brighter!
Jason
Follow my Jeep Builds!
jeepbuilds.blogspot.com
Jsadamson1 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 08:03 AM   #5
ThisGuyUKnow
Most likely your headlamp/dimmer switch is bad, very common issue. You can get replacement at must auto stores.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 09:13 AM   #6
texasdave
texasdave's Avatar
1980 CJ7
There is no fuse for the headlights it is built in to the switch.
texasdave is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 09:29 AM   #7
walkerhoundvm
1981 CJ8
And oftentimes not even bad - just needing a good jiggle. Better grounding, maybe?
walkerhoundvm is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 10:20 AM   #8
ThisGuyUKnow
No it's because of how the connections are in there they are exposed and corrosion gets between the contacts. The head lights are grounded at the grill. The switch simply passes 12v to the lamps.
If your having to jiggle your switch to get the lights to work I'd go ahead and replace it out buy a replacement to keep in the glove box.what will happen is the switch will heat up from the resistance caused by the bad connection andburn out the switch. And it will do that in the middle of the night when it's must inconvenient.
Had to sleep in the cj on i55s shoulder cause it burned out at 8pm and it was too dangerous to keep moving in the dark.
Also everything passes through your floor switch too, that can also go bad on ya and should be ruled out.
Unread 04-29-2015, 10:29 AM   #9
walkerhoundvm
1981 CJ8
When I bought my CJ 5 years ago - the PO said it didn't have high beams. I found the high beam switch, jiggled it, and they've worked ever since
Unread 04-29-2015, 11:15 AM   #10
ThisGuyUKnow
Your taking about the floor switch which is separate from the dash switch.
Unread 04-29-2015, 11:54 AM   #11
walkerhoundvm
1981 CJ8
NO, you're talking about the dash switch which is different from the floor switch which everyone else in this thread is talking about.
Unread 04-29-2015, 12:20 PM   #12
my_304_cj7
1976 CJ7
I 500,000th the floor dimmer. I would disagree with buying a new one until you know there is nothing that can be done for the old. I bought a replacement that didn't work from day one. I don't remember exactly what I did but I was able to get the original working and I haven't had an issue since.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 01:11 PM   #13
ThisGuyUKnow
Well last I checked the dimmer switch was on the dash as it dims your gauges. But I suppose I could be mistaken and all this time been calling the floor switch by the wrong name.
Unread 04-29-2015, 01:39 PM   #14
Mike Romain
Different places call it different, I for sure was talking about the floor switch that dims or brightens the headlights or high/low beam switch. They can get half on/off and need a kick or the plug can fall out or get corroded real easily being on the floor and all.
Mike
Unread 04-29-2015, 01:41 PM   #15
walkerhoundvm
1981 CJ8
Did you hear about the blonde who get into an accident? She got her foot stuck in the steering wheel trying to hit the headlight dimmer one night.
