86 cj7 difficult to shift pops out of 1st - JeepForum.com
post #1 of 42 Old 01-28-2010, 02:27 PM Thread Starter
mastercraftka
mastercraftka's Avatar
when I put it in 1st gear and let out on the clutch it pops into neutral. If I really put my weight beind it, then it will stay in gear but shifting into and back down gears is really stiff. I hear no noises or grinding of gears or transmission noises any ideas. It is an 86 cj7 four speed manual.
mastercraftka is offline
post #2 of 42 Old 01-28-2010, 03:29 PM
boomvader
If I remember back to my days of youth with my 83 CJ-7 and T5 transmission, I think you have a bad synchronizer gear.
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #3 of 42 Old 01-28-2010, 03:34 PM
80cj
80cj's Avatar
1980 CJ5
Is there a body lift on it that may be limiting full movement of the shifter stick?
80cj is offline
post #4 of 42 Old 01-28-2010, 03:55 PM
mcurcio1989
1976 CJ7
I have never worked on a t5 but when my t150 was doing that it was the synchros. Wasn't all that bad to fix.
Disregard everything i say
I have a dana 30 front axle and amc 20 rear if anyone is looking. Both are 3.54, drums, narrowtrack.
mcurcio1989 is offline
post #5 of 42 Old 01-28-2010, 04:20 PM Thread Starter
mastercraftka
Yes it does have a lift but it has been shifting fine for months now and i pulled the boot off to see when i am shifting and could only be hitting when in reverse 2nd or 4th and it is same in all gears but only popping out of 1st. So if it is the synchronizer gear what does that take to fix?
post #6 of 42 Old 01-28-2010, 05:29 PM
only in a jeep cj
Removing the transmission from the Jeep and rebuilding it with new synchronizers. Might as well do new bearings and small parts while in there.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #7 of 42 Old 01-28-2010, 06:10 PM Thread Starter
mastercraftka
boo!! oh well is it bad to drive it short distances like it is until i can find time to pull it off?
post #8 of 42 Old 01-28-2010, 08:36 PM
only in a jeep cj
I would say no, it shouldn't hurt it anymore than it is mainly if its not making any grinding or strange noises while in gear. Try not to let it pop out and slam out of gear though. I have a unit that pops out of first gear, so I got in the habit of holding the gear in place until it was time to go into second....no problems.
Ed
1975 CJ-6 1983 CJ-8
post #9 of 42 Old 01-29-2010, 02:14 PM Thread Starter
mastercraftka
Ya i have been holding it and if i really push on it hard it will stay in gear. Just difficult to change gears. I was thinking about taking it out myself and seeing if i could get someone to work on it, what do you think i should expect to pay someone to fix this?
post #10 of 42 Old 01-29-2010, 02:48 PM
only in a jeep cj
HArd to say, you save some money pulling it and reinstalling it yourself, but I would get prices bothe ways just to see if its worth all the BS of having to mess with it. If you only save a hundred or so, let them do it.
I would be guessing, but in my area, about 600 to 1400 parts and labor. I've learned how to rebuild them myself and save a ton of money, but you have to have the tools, time, and know how.
Ed
1975 CJ-6 1983 CJ-8
post #11 of 42 Old 01-29-2010, 05:49 PM
mcurcio1989
1976 CJ7
I am not sure how the t5 and t150 compare but mine was fairly easy. I got all the parts for about 100. Honestly the hardest part was getting the transmission out. The job did not require any special tools. Your supposed to use brass drifts for a couple things but for me a wooden dowel sufficed. If you enjoy working on your cj and learning how thinks work i would say go for it. These are old American made manual transmissions. They are not exactly rocket science.
Do some searches on rebuilding the t5.
Btw mine did exactly that. It first started where it would occasionally pop out of second and then it got to the point where i had to push to hold it in. Eventually it will get to the point where it will not stay in regardless.
post #12 of 42 Old 02-01-2010, 03:04 PM Thread Starter
mastercraftka
Ya i want to save money and i think if i get if off and have my dad around, he is a mechanic from long ago when engines were more simply, i think we can probably make it work. Wasn't looking forward to transmission problems but oh well.
post #13 of 42 Old 02-01-2010, 03:29 PM
Coiz
1979 CJ7
It is likely the synchro but also be sure to check the shift fork and rails for being bent.
Mike
Coiz is offline
post #14 of 42 Old 02-01-2010, 03:46 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
T5 he says in his first post "It is an 86 cj7 four speed manual."
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #15 of 42 Old 02-01-2010, 06:18 PM
mcurcio1989
1976 CJ7
yikes i dunno why i said that. For some reason i thought i remembered reading that he said it was a t5. . . So i guess its prly a t18 then.
dana 300, difficult to shift, stock shifter nicknoty Jeep CJ Forum 12 07-17-2009 07:11 AM
How difficult would this be Jeepguy91 Jeep CJ Forum 3 06-06-2009 01:01 AM
How Difficult it is... DeltaSigCJ5 Jeep CJ Forum 3 10-12-2007 11:33 AM
which is most difficult??? OlllllllO JEEP Jeep CJ Forum 4 01-05-2002 09:18 PM
How difficult is it to .... GRUB Jeep CJ Forum 3 12-26-2001 07:26 AM
