86 CJ7 258 New GM HEI but no spark - Page 2 - JeepForum.com
post #16 of 18 Old 03-27-2012, 01:04 PM
Jacoby22
1983 CJ7
are your wires in the right spots on that cap? was the dizzy pulled when you were trying to look for tdc on #1? are you sure you were on the right stroke on the motor?
Jacoby22 is offline
post #17 of 18 Old 03-30-2012, 07:12 PM Thread Starter
planb722
Reran my wires and I had crossed #5 and #6. Now it's running much better. Took it for a test drive and about 5 minutes in it died. Like it was out of gas but I know that it had plenty. Got it to restarted after a few minutes. Made it about 3 more miles and it did the same thing. Any suggestions?
planb722 is offline
post #18 of 18 Old 03-30-2012, 08:21 PM
TrebleHook
1979 CJ7
Hmmmm...sounds like a fuel thing - not an ignition thing. Vapor lock?
Somebody with Jeep brains will answer up shortly! I suggest you give as much detail as you can (carb? initial timing? etc...) and let the forum do it's magic!!
Cheers,
TrebleHook
1983 CJ8 Scrambler Laredo - 258 MOPAR MPFI/T-5/Dana 300 - 4.10 Dana 44 Rear/Dana 30 Front w/ ARB lockers front/rear - 4" BDS Suspension w/ Fox 2.0 Shocks - Ground Pounder Fab Front Shorty and Rear Spare Custom Bumpers - PSC Steering w/ Borgeson Shaft - 33x10.50 BFG KM2 on 15x8 Mickey Thompson Classic III - Work in progress.....
TrebleHook is offline
distributor , hei , help please , no spark , no start
No spark from distributor to spark plugs poolshark909 Jeep CJ Forum 14 08-06-2013 04:36 PM
no spark CJ7 heykolohe Jeep CJ Forum 2 08-24-2011 02:47 AM
HEI, Weak spark at coil, no spark at plugs Deadman 94 xj Jeep CJ Forum 13 07-30-2011 08:49 AM
no spark! petey156 Jeep CJ Forum 1 05-30-2006 05:08 PM
No Spark to the spark plugs Dandude80cj7 Jeep CJ Forum 6 09-11-2005 09:02 PM
