86 Cj-7 Spark Inconsistent I6 - JeepForum.com
post #1 of 4 Old 02-13-2015, 10:24 AM Thread Starter
SouthTxAggie
I know the ignition posts have been hit hard but i feel i have a weird Case. if you watch the spark from the wire being held close to the Distributer and turn it over it starts out strong then weakens then goes out then comes back etc. It will not try to start at all, had one back fire from dumping fuel in the Carb. I have checked the Engine Module with a new one and that did not change anything. Could this be the Pick up coil in the distributer? or a bad ground somewhere? The odd thing is if you turn the Key off it has an intermitent spark at the coil. This Jeep sat for a year or so and tryed to idle at one point but lost fuel. I replaced the Fuel pump and got fuel to the carb and cannot even get it to fire by dumping gas in it. Firing order is on and time has not effected it. Also has all fresh plugs
thanks for the Help
SouthTxAggie is offline
post #2 of 4 Old 02-13-2015, 11:30 AM
Rolandt03
1983 CJ7
I would check the coil itself, if they get to hot they will go bad. check connections at the coil as well.
Rolandt03 is offline
post #3 of 4 Old 02-13-2015, 01:57 PM Thread Starter
SouthTxAggie
Thanks, could this also be symptoms of the pick up coil in the distributor?
post #4 of 4 Old 02-13-2015, 06:18 PM
Mike Romain
Yes it could, but normally they just trigger the spark, they don't really control it. The ohm reading between the orange and purple wires should be 650 with a range between 400-800 according to the book. Mine failed at 485.
Mike
Mike Romain is offline
