85' CJ7 will turn over but will not start. - JeepForum.com
post #1 of 15 Old 07-27-2009, 12:55 PM Thread Starter
HRW85CJ7
I have a 85' CJ7 with the original 258ci straight 6. Problem: Major difficulties starting when cold. It turns over strong, but will not start. Once its running. It runs strong and starts without incident. I have put in a new fuel pump and rotor, and have rebuilt the Webber carb. Any ideas? Thanks.
HRW85CJ7 is offline
post #2 of 15 Old 06-03-2013, 08:04 PM
jguess1
I have the same problem now, minus the cold part. Mine will turn over but not start. It was running fine and now will not start. How did you end up fixing your problem?
jguess1 is offline
post #3 of 15 Old 06-03-2013, 08:08 PM
tljones210
You probably have looked, but I had a tear in vacuum hose where it bent under carb. Looked fine until I really stretched it straight. It would try and start, and crank intermittently until it got to far gone. Easy solution and good place start.
tljones210 is offline
post #4 of 15 Old 06-03-2013, 08:46 PM
jguess1
Awesome I will try to pick one up tomorrow and give it a try. Thanks for the cheap recommendation.
jguess1 is offline
post #5 of 15 Old 06-03-2013, 09:27 PM
rplivin
Check the operation of the choke also. If its not adjusted or working properly you will have cold start issues. Also if you have the factory filter make sure it's orientated correctly.
rplivin is offline
post #6 of 15 Old 06-05-2013, 08:28 PM
jguess1
Vacuum hose was the fix. Thanks for your help!
jguess1 is offline
post #7 of 15 Old 06-07-2013, 02:16 PM
tljones210
Got to love it when it is cheap and easy... the few times it actually works out that way at least
post #8 of 15 Old 06-07-2013, 02:29 PM
cj5huntingrig
1974 CJ5
9 times out of 10 it's vacuum related on these engines
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #9 of 15 Old 06-15-2013, 03:32 PM
jguess1
Not sure if you saw my other post
Ok so I thought my problem was fixed but its not. Turns out I am not get fuel to carb I guess. I just pour a few drops directly into the carb and it started right up. Then it ran fine until I turned it off. What would you all recommend to do first. I just replaced the fuel filter and lines from the electric fuel pump to the carb.
jguess1 is offline
post #10 of 15 Old 08-19-2013, 09:02 PM
RobinMasters
I was having a similar problem - jeep would run but when I left it sitting for any period of time, it wouldn't start. checked the ignition module, coil and distributor and was getting a good spark. Also ran through the entire fuel system and everything seemed fine. There were 2 very simple issues.
First thing you want to check is that your fuel filter is installed correctly. The 2 outlets need to be positioned properly - the line running to the carb must be at 6 'o clock and the return line at 12' o clock. If installed upside down or sideways the fuel has to fill the filter before it will pump into the carb...gravity needs to do its job.
Second thing to check is the needle valve on the fitting going to the carb. Problem I found (after wasting several hours looking everywhere else) was that the needle valve was sticking. Took out that fitting and noticed that the needle wouldn't fall out. Tried to blow it out with my mouth (gotta be able to blow 10+ psi), and wouldn't move. Fuel line only has about 7 psi... Got a new fitting and needle valve with a rebuild kit ($20) and since replacing it, the jeep starts great.
RobinMasters is offline
post #11 of 15 Old 08-19-2013, 10:50 PM
BagusJeep
1981 CJ7
jguess1,
You need to be methodical about your investigations and test rather than assume and replace.
I have picked up that you have an electric fuel pump of unknown capbilities, a three way fuel filter and a Weber carb,type unknown.
First thing is to check the ignition is working correctly, a strong crisp spark. Check you have battery voltage (12V) at the coil in Start and about 7V otherwise.
Next thing is to check fuel flow. You have an electric pump so unhook the line from the carb and put it in a bottle.Turn on the ignition and see how much fuel you get.
If you get a good amount it is not the fuel supply.
Next take the top off th ecarb and pump the throttle linkage. If you get a good spurt of fuel you have fuel in the carb.
Next thing to check is choke and mixture. Get yourself a manual and chack the choke is set up properly. No offence intended buit also check you are following the correct procedure for starting with that carb.
Last thing is to check all vacuum hoses for splits etc. And then the manifold gaskets.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #12 of 15 Old 08-19-2013, 11:26 PM
MountainHound
MountainHound's Avatar
1979 CJ7
x2
If you have fuel, good spark then I check the carb as it sounds like a choke issue. Hard to say without knowing exactly the carb. type and what type choke etc... .
1979 CJ7
2011 WK2
MountainHound is offline
post #13 of 15 Old 08-20-2013, 12:44 AM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Originally Posted by MountainHound View Post
x2
Did any one realize the first post was from 2009?
As stated fuel filter connections and if you still have the Carter bbd the float loves to stick also not allowing gas flow.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #14 of 15 Old 08-20-2013, 12:54 AM
MountainHound
1979 CJ7
nope...need to look more carefully at the post dates from now on
1979 CJ7
2011 WK2
post #15 of 15 Old 08-21-2013, 04:08 AM
BagusJeep
1981 CJ7
Yep, but jguess1 resurrected it, a zombie thread maybe but a current problem.
Key lock cylinder won't turn to start/run mitchmoody Jeep CJ Forum 5 10-20-2009 11:40 AM
Won't start, nothing happens when turn the key hilton00 Jeep CJ Forum 8 03-04-2009 08:34 AM
When I turn key, battery gauge pegs, but engine doesn't turn over part.changer Jeep CJ Forum 30 12-17-2007 05:34 PM
Got CJ to turn over but still won't start XJMudder Jeep CJ Forum 32 08-07-2007 08:15 PM
Turn signals turn on but dont blink JDGordon Jeep CJ Forum 6 02-27-2006 06:17 PM
