85 CJ7 T5 Shifter - JeepForum.com
post #1 of 8 Old 07-02-2007, 05:36 PM Thread Starter
Timberdoodle
85 CJ7 T5 Shifter
Hi, this is my first post. My trans shifter works OK but it is very loose. Where can I get the nylon(plastic?) sleeve that is on the base of it? After owning this for 19 years, I finally put an HEI dist in and am now installing a 2100 carb. It still has the original paint and I have the original rag top.
Timberdoodle is offline
post #2 of 8 Old 07-02-2007, 06:29 PM
1984CJ
1984CJ's Avatar
You can find them on ebay sometimes being called an isolator and clip.
That is where I found mine.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #3 of 8 Old 07-03-2007, 07:21 AM
Happy Joe
You can find them in a U-pull-it type junk yard. They are also used in 87 YJ transfercase shifters and other shifters too. It is usually easier to get another shifter for a T-5 or T-4 transmission (be carefull, they are not all exactly the same, some of them are bent at different angles just above the shifter plate).
Enjoy!
Happy Joe is offline
post #4 of 8 Old 07-03-2007, 10:23 AM
JoonHoss
2011 JK Wrangler
I had the same issue, and couldn't find a repalcemnt clip anywhere...without getting too in depth, I skipped the whole isolator clip, and tacked on two nuts/set screws, which firmed it right up- let me know if you want more info or a how to
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #5 of 8 Old 07-03-2007, 02:05 PM
wm69
http://cgi.ebay.com/ebaymotors/Jeep-...spagenameZWD1V
see if this guy has anymore of them. I've got a B&M shifter and it's really not that much better than the stock shifter was after I replaced the isolater and clip.
wm69 is offline
post #6 of 8 Old 07-07-2007, 09:17 PM Thread Starter
Timberdoodle
T-5 Shifter clip
Many thanks to everyone that replied. I haven't found one yet. I talked to an old mechanic that has an 86 with the T-5 and he just drove a piece of pvc tubing down the shifter. He said it worked. Any comments are welcome.
post #7 of 8 Old 07-09-2007, 03:09 AM
ChiliPepperTJ
ChiliPepperTJ's Avatar
Mine needed the new isolator and clip. I got them from the dealer a few years ago. Its worth a try.
Kevin
84 CJ-7 Renegade- 258,GM TBI w/ ESC, HEI, T-5, D300, D30, AMC 20 w/ trac loc and superior shafts, 2.5" BDS lift, 1" daystar BL, MORE shackles, Tie rod flip, 33" Swamper SSR's, Full cage, OBA, A to Z rocker guards, A to Z rear cage, Warn 9.5ti, Taurus fan, Herc'd tub, LED tail lights, Hand throttle, Hella Fogs, Hella headlight conversion, more to come...
02 WJ Limited, 4.7 H.O., RB1 Nav, DD and toddler hauler
Checkout my Junkyard TBI writeup:
ChiliPepperTJ is offline
post #8 of 8 Old 07-21-2007, 09:12 PM Thread Starter
Timberdoodle
T-5 Shifter clip and isolater
Thanks to all that replied. I got one from a Dodge dealer in a town 30 miles away. It was cheaper than from eBay.
What is the thread size of the manual shifter and 4wd shifter? HHICJ7 Jeep CJ Forum 7 09-25-2009 12:05 PM
t-176 shifter petey156 Jeep CJ Forum 3 11-11-2007 02:02 PM
column shifter to floor shifter TJbino4 Jeep CJ Forum 0 09-14-2007 05:25 AM
Transfer case, the big shifter, the little shifter, and oddness senaTTor Jeep CJ Forum 10 10-17-2006 06:52 PM
New T176 shifter pins and shifter fork!! sampson9dk Jeep CJ Forum 0 06-17-2003 02:20 PM
