Quantcast 85 CJ7 shock question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 85 CJ7 shock question
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 01-08-2006, 05:58 PM   #1
jeromehdmc
I'm putting a set of 1in. lift shackles on our jeep, will the stock length shocks work or will I have to get longer ones?
jeromehdmc is offline   Reply With Quote
Old 01-09-2006, 05:44 PM   #2
cyclic17
1981 CJ7
Is that all you're doing for lift?
What kind of driving do you do with it? If it is just a pavement-only DD, I would think you'd be fine with stock shocks.
If not, I've got some brand new BDS shocks for a 4" lift that I'll make you a screaming deal on.
*'81.5 CJ7, D300, T-5, 258ci, 4" BDS lift, 33 's on 15x10 Bajas, Narrowed Waggy D44 Front, Scout D44 rear w/ARB locker, Not-so-Painless Wiring Harness, Warn 8274, Borla Headers, MC2100 carb, Shrockworks sliders, KC's, Full cage
*RIP: '88 Comanche Chief, stock except for KC lights on rollbar and custom stereo.
cyclic17 is offline   Reply With Quote
Old 01-09-2006, 07:02 PM   #3
jeromehdmc
For now that's all I'm doing, The bushings were worn out, and the stock shackles were not in the best shape. I am putting poly bushings and the longer shackles on. This is my wife's first car, she bought it in 86, and I doubt she wants to do much trail running in it, just a little off roading. Thanks for the info.
Old 01-12-2006, 10:16 PM   #4
tomass15
You should be fine on the up travel, the down travel may hang by the shock limiting the axle drop. When your done installing the shackle, unhook one end of each shock, then jack up the rig by the frame so the axle can hang by the spring, then extend the shock to see if it reaches the mount you took it off of.
For the driving it sounds like your wife does you should be fine, but the above is a easy to check it, then keep it in mind when you get her new shocks some day.
tomass15 is offline   Reply With Quote
Glock Forum
