85 CJ7 fuel vapor canister - JeepForum.com
post #1 of 4 Old 05-16-2013, 02:08 PM Thread Starter
85project
I am rebuilding my CJ and am putting in a new fuel tank, sending unit, straps, lines, and I found that my canister is dry rotted, I can not find one new or AM. I read that I can use an 93 jeep grand Cherokee can. Has anyone tried the conversion or have any other ideas?
Ty
Greg
85project is offline
post #2 of 4 Old 05-16-2013, 02:24 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Use the 93 one. Go to Oreillys and they will price match the 25.99 that NAPA has. Or go to NAPA and get one. I just usually go to Oreillys.
Here are the easiest instructions I have found. I am picking mine up in the morning so I can finish tuning my new Weber.
http://www.ifsja.org/forums/vb/showthread.php?t=106051
Good Luck
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #3 of 4 Old 05-16-2013, 06:46 PM
INowUnderstand
Just did this. Works great. 93 will just drop in to the old bracket. That write up above will do ya.
One tip when you drill out the closed off port, start with a very small drill bit to get it centered on the port. Then work your way up. Starting with a large bit wanted to slip and chew up the port. It's short,so you don't have much room to lose by tearing up on the end
INowUnderstand is offline
post #4 of 4 Old 05-16-2013, 06:49 PM
INowUnderstand
Buy the way. Autozone couldn't order it. Vendor out. OReilly's could. Had it the next day. 93 cherokee
