-   -   85 cj wont move?? (http://www.jeepforum.com/forum/f8/85-cj-wont-move-1473085/)
JHO85cj 02-02-2013 11:39 PM
85 cj wont move??
i have an 85 cj 7 all stock 4cyl with manual 4 speed, i can put it in any gear and it will not move, both front and rear driveshafts are spinning but no movement, i have also tried the transfer case in every range and still nothing at all
bajaviking 02-03-2013 12:07 AM
When you say driveshafts are spinning you mean with the motor running you put it in gear and you can see the shafts spinning but the jeep just stands still:confused:
If that is the case your hubs in the front would have to be unlocked and at the same time your rear diff is damaged.
chesapeakcowboy 02-03-2013 12:27 AM
If your driveshafts are turning and vehicle isnt moving ...front hubs probably not locked in and you have broke an axle or something in the rear axle...sometimes you got to drive home on front wheel drive
Truck633 02-03-2013 09:24 AM
X2 on the rear axle..
lock in the front and let us know if she moves
lucdog 02-03-2013 12:11 PM
Is the entire rear driveshaft spinning, ( both ends) or is just the part connected to the transfer case,
RobsCrawlin7 02-03-2013 12:35 PM
Originally Posted by truck633 (Post 14899290)
x2 on the rear axle..
Lock in the front and let us know if she moves
x3
The time now is 10:07 AM.
