85' CJ Ignition problem - Page 2 - JeepForum.com
post #16 of 24 Old 09-12-2012, 05:33 AM
Hawk4097
Go buy a compression gauge. They arent that expensive. remove all your plugs and wires(label the wires so you know where to put them back to) screw in the compression gauge into each cylinder have someone turn the engine over while you read the gauge. if you have little to no compression at any cylinder you could have a stuck valve or a hole in your piston or even bad piston rings.
Hawk4097 is offline
post #17 of 24 Old 09-12-2012, 07:16 AM
Oldcraneguy
1982 CJ7
You have spark and gas, the only things left are compression and timing. Get a compression tester and check all cyls, if theyre uniform (+ - 10 lbs) then its a timing problem. If thats the case pull the distributor (making a note as to where the rotor is pointing) and check the drive gear. If compression is all over the place (20-100) its time to pull the front off. If you find chewed up gears you also need to pull the valve cover and check for bent pushrods and and pay close attention to the valve stem height, I would pull all the rockers and look for any valves that arent all the way up (1/8" makes a big difference) I think I might be getting ahead of things here, do your comp check and get back to us... good luck...ocg
Oldcraneguy is offline
post #18 of 24 Old 09-16-2012, 03:22 PM Thread Starter
msgrogan
#1 = 110-115 lbs
#2 = 110-115 lbs
#3 = 90-95 lbs
#4 = 120-125 lbs
#5 = 120-125 lbs
#6 = 110-115 lbs
Going to check to see if the timing is off and how to get it in the correct order. What makes the timing jump? Should I get a new belt or distributor once I get the timing fixed so it won't happen again?
msgrogan is offline
post #19 of 24 Old 09-16-2012, 05:24 PM
86cj74.2L
86cj74.2L's Avatar
Was those numbers with all plugs removed and throttle held wide open.
86cj74.2L is offline
post #20 of 24 Old 09-16-2012, 06:23 PM Thread Starter
msgrogan
No throttle was not wide open.
msgrogan is offline
post #21 of 24 Old 09-16-2012, 06:33 PM Thread Starter
msgrogan
Going to replace ignition control unit next weekend just to rule that out. Probably going to take it to a mechanic to adjust the timing if that doesn't work. Don't want to tackle that job.
msgrogan is offline
post #22 of 24 Old 09-16-2012, 08:27 PM
86cj74.2L
86cj74.2L's Avatar
Held wide open throttle with all plugs removed and battery at 100% is proper way to check compression.
post #23 of 24 Old 09-17-2012, 05:33 PM Thread Starter
msgrogan
Replaced ignition control unit. Same scenario. Its heading to the mechanic this weekend. Pretty sure it's a timing issue. If I continue to keep the ignition engaged it sounds like it's running. As soon as I let off it stops.
msgrogan is offline
post #24 of 24 Old 09-24-2012, 05:11 PM Thread Starter
msgrogan
There was a ignition kill switch underneath the dash. Started tugging on wires and found a heavy gauge wire that came loose from its barrel connector. Fired right up!
msgrogan is offline
carberator , cj7 , fuel pump , ignition problem
ignition problem jpenrod Jeep CJ Forum 7 04-15-2011 07:47 AM
82 cj5 ignition problem shiner08 Jeep CJ Forum 1 01-22-2011 05:05 PM
Ignition problem HEI and CDI Dngrs1 Jeep CJ Forum 28 03-13-2010 12:48 PM
Ignition Problem tahoe wheelers Jeep CJ Forum 4 07-01-2009 12:12 AM
Help..Ignition problem freedomrik Jeep CJ Forum 7 06-12-2009 05:56 PM
