-   -   85 CJ-Directionally Challenged Jeep.. (http://www.jeepforum.com/forum/f8/85-cj-directionally-challenged-jeep-1573660/)
WolfDawg 09-09-2013 08:06 PM
Hi, guys! It's been awhile, I know...I've missed ya! But, I've been busy playing, camping, trail running, triathleting...
And, now...my girl seriously has an issue...
She only drives in reverse....but, only if I put her in fifth gear...while in 4WD.
Any ideas? It literally happened out of nowhere....I made a trash run one day, and a mile away from the house she just stopped moving forward while in gear. And the only gear that works is fifth...but in 4WD...and instead of forward, she goes backwards.
It was tons of fun driving back home in reverse.:2thumbsup::cheers2:
So...any ideas would be more than welcome!
Thanks, guys!
WD
Stormpaw 09-09-2013 09:11 PM
Wow! That is crazy. It sounds like a t-case problem, but I can't even begin to guess how that would happen.
Good luck.
BagusJeep 09-09-2013 09:24 PM
Only in 4WD, have you got drive to the rear axle???????
As to only being in reverse, have you got gear selector issues in the box?
Stormpaw 09-09-2013 09:32 PM
Oh wait, you have a T5... I blame the T5. :D
WolfDawg 09-09-2013 10:39 PM
Yes, I've got all gears....can put it in gear. It's just that none of the gears engage. I can go 4 low and 4 high. None of the gears engage...except fifth, in 4-Hi, and when I can get it there....it goes backwards.
Hawk4097 09-10-2013 08:20 AM
I'd just bite the bullet and take it to shop
jp360cj 09-10-2013 09:17 AM
When it will move in 4Hi, is the rear driveshaft getting power? Are the hubs locked in to allow the front axle powering the vehicle? Only moving in 4x4 (with front hubs locked in) usually makes think a spun hub/broken shaft on a 2 piece axle. Also, pull the top cover off the transmission and check the shift forks and inside of the transmission.
WolfDawg 09-12-2013 07:47 PM
Bit the bullet...called my Jeep guy...details to come.
VACJ7 09-12-2013 07:55 PM
Can't help but your thread title cracked me up!
WolfDawg 09-12-2013 08:17 PM
It was hilarious driving her home....in reverse!
Hopefully, she'll be back to normal before too long.:cheers2:
scoutboater 09-13-2013 07:43 AM
2 Attachment(s)
Reverse in 5th gear sounds like shift forks to me, but that doesn't explain it only working if 4Hi. So then I thought a body lift shifted messing with stuff, but you don't list one in your profile. So now I'm wondering if your body mounts are shot and your tub shifted on the frame?
In reality, I think you've got more than one problem, and for some stupid unexplainable reason they all showed up at once....
Renegade82 09-13-2013 01:25 PM
I don't have any long term solutions but have you thought about having an exorcism for the Jeep? ;) That's just strange!
The time now is 01:05 PM.
