85 cj amc 304/ t5 what clutch do i use? pilot bearing? - JeepForum.com
post #1 of 7 Old 02-25-2010, 05:07 PM Thread Starter
sbcranger
i was going to go ahead and order a clutch being my is getting to to the end its life. i just wanted to make sure, but are all t-5's a 10 spline input? and what pilot bearing/bushing do i use? im assuming that the bushing/bearing for a 258 will not work with the 304 crank.
sbcranger is offline
post #2 of 7 Old 02-26-2010, 07:25 PM Thread Starter
sbcranger
can anyone point me in a direction at least as far as the pilot bearing? i know i saw a thread on here that went into it but i cant seem to find it in any of my searches. and id really prefer to be able to have everything to change the clutch rather than pull everything just to find out what pilot bearing/bushing is in there
post #3 of 7 Old 02-26-2010, 08:10 PM
Fatman
Fatman's Avatar
2008 CJ7
1 1/8" - 10 spline for the clutch disc.
Pilot bearing will depend on the year of your 304
Thread Links:
Fatman is offline
post #4 of 7 Old 02-26-2010, 08:46 PM Thread Starter
sbcranger
thanks fatman- is there a quick way to ID what year it is? im assuming that there are 2 different crankshafts, other than the "304" casted into the side of the block i havent noticed any other numbers or anything to ID it
post #5 of 7 Old 02-26-2010, 08:49 PM
jeepmaster03
1982 CJ7
Call the guys at Novak adaptors. They can get you exactly what you need.
jeepmaster03 is offline
post #6 of 7 Old 02-27-2010, 06:18 AM
Mike Romain
The 258's T5 uses a pilot bushing, I think the 304 also uses one. The ID code for the 304 should be on a plate on the passenger side valve cover. If there are two cranks, I would just buy both bushings or bearings and return one.
There also should be an oil wick in behind the pilot bushing that needs to be pulled out and re-oiled.
Mike
Mike Romain is offline
post #7 of 7 Old 02-27-2010, 09:40 AM Thread Starter
sbcranger
thanks, Romain, i would have done that but the tag and stock valve covers were unfortunately long gone before me.
Noisy pilot bearing??? CJ-Jay Jeep CJ Forum 3 05-01-2009 11:31 AM
Pilot Bearing Trouble!!! Please Help!!! ALLBEEF Jeep CJ Forum 18 01-10-2009 12:51 AM
Pilot bearing stephens_cj5 Jeep CJ Forum 12 12-21-2007 01:21 PM
pilot bearing ademster Jeep CJ Forum 9 10-11-2006 08:52 AM
Pilot Bearing/Bushing jeepsarecool Jeep CJ Forum 7 07-17-2006 08:49 AM
