85 CJ-7 shifter retaining tab - JeepForum.com
post #1 of 8 Old 09-21-2017, 08:12 AM Thread Starter
DocH60
I am looking for the metal locking tab that holds the shifter to the transfer case, vendor or part number would be great
thanks in advance for any info that can be providedName:  retaining clip.jpg
DocH60 is offline
post #2 of 8 Old 09-21-2017, 08:18 AM
keith460
Jeep. There's Only One
keith460's Avatar
There is no metal tab for the Transfer Case shifter, only the T4/5 and SR4 manual transmission shifter.
They can be found here: https://www.quadratec.com/products/52112_0200.htm
1984 CJ-7 Renegade
keith460 is offline
post #3 of 8 Old 09-21-2017, 08:28 AM
pedal2themetai
1956 CJ5
Hi can't you just re-bend the tabs that lock it on??
good luck
tim
pedal2themetai is offline
post #4 of 8 Old 09-21-2017, 11:27 AM Thread Starter
DocH60
That is the culprit, sorry for any confusion and Thank You for the Link. After 32 years at the Beach, it just gave up, lol
DocH60 is offline
post #5 of 8 Old 09-23-2017, 09:33 AM
NormWild
You are better off just drilling it and running a bolt through it. I would recommend drilling front to back and not side to side. Learned from experience and had to drill it twice.
2008 FI C6
2016 Diesel Colorado
NormWild is offline
post #6 of 8 Old 09-23-2017, 10:18 AM
JoonHoss
2011 JK Wrangler
Two thin nuts, two Allen head set screws.
Use the one existing hole in the shift base handle, drill another 90 degrees opposite.
Tac weld the nuts, use the set screws to tension.
Done
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #7 of 8 Old 09-23-2017, 02:27 PM
keith460
keith460's Avatar
I knew suggestions like those were coming, they always do. But sometimes others simply like the way the factory has the clip and isolater setup that is just as easy and reliable. 50,000 miles at least from the constant shifting.
1984 CJ-7 Renegade
keith460 is offline
post #8 of 8 Old 09-23-2017, 07:19 PM
JoonHoss
2011 JK Wrangler
Oh, I recognize it's not the only option, but it is a viable option for which does work (very well)
When I figured it out originally, I had suffered thru a good 6+ months of terrible, sloppy shifting due to a terrible condition isolator clip. (My buddy said it was like trying to shift with a piece of empty garden hose)
I'd like to think I'm pretty Jeep speak adept, but had no idea an isolator clip existed, or that it was called an isolator clip. Tuff to search for what you don't know.
Hoss
JoonHoss is offline
