84 CJ7 Tail Light Wire Colors & Functions? - JeepForum.com
post #1 of 5 Old 03-08-2011, 02:56 PM Thread Starter
cpistorius
Hi all,
Trying to replace my tail lights and the new wires are black, red and white. The original wires are White, White w/TR and Green, can anyone tell me how they map to each other? Thanks!
cpistorius is offline
post #2 of 5 Old 03-08-2011, 03:31 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
white markers jumpered between the lights, green w/trace is left turn/stop, light green is right turn/stop.
You need to check your lights they should have came with wirring set up and compare it to that.
one of the wires off the new lights is more then likely ground. Just ground it to the body or carry it forward for a dedicated ground.
if i remember it correctly as the harness goes through the tub on teh drivers rear it junctions up there and then jumpers over to the passenger side
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #3 of 5 Old 03-08-2011, 03:41 PM
Coiz
1979 CJ7
White is the tail lights, white w/tr is reverse lights, Lt Green is right turn/hazard and Lt Green w/tr is left turn/hazard.
As far as what hooks to the black, red and white, I would hope it would have come with instructions. If not, install the bulbs, provide a ground to the housing and power the wires individually to figure what wire controls which bulb filament. Reverse should be easy to figure out. The other two, one will be dim for the running lights and the other will be brighter for the turn/stop/hazard.
Mike
Coiz is offline
post #4 of 5 Old 03-08-2011, 03:48 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
Darn...forgot about that freaking back up light!
post #5 of 5 Old 05-23-2011, 12:14 PM
alljagged24
Bump
alljagged24 is offline
cj7 , tail lights , wiring
CJ tail light pig tail tydp Jeep CJ Forum 1 08-10-2010 04:24 PM
Tail light/brake light confusion..... Skinnyfeet Jeep CJ Forum 3 08-14-2009 09:13 AM
Please help w/Nutter - different wire colors idl Jeep CJ Forum 6 05-09-2009 05:01 AM
Horn Relay location-wire colors Totallymetal Jeep CJ Forum 7 08-30-2007 10:23 PM
Melted ruined wiring harness...need some wire colors CaryW Jeep CJ Forum 2 09-09-2003 09:23 AM
